Question about Refrigerators
I have two whirlpool refrigerators. Both have the same problem. The defrost drain and drain pan under the evaporator coil freeze. Then the defrost cycle causes water to drip down into the frig section. At that point I have to remove the ice maker and evapoator cover to access the frozen drain pan. After getting the ice to thaw all the way down in the drain hole, I get to put it back together and reload the freezer. Do you have any solutions for this evident design flaw. I had bought the second refrigerator for a vacation home before the problem started on the first refrigerator. ET2IMMXJW00 MFG.DATE 06-00 and ETIFHMXMQ00 MFG.DATE 08-04.
  • 828 Answers
Under the cabinet in the back is a drain tube with a loop for air seal. this loop will sometimes become plugged. Clean it and it may resolve your problem. I use a small section of automobile speedometer cable as a mini roto rooter.
Posted on May 03, 2008
The drain freezes from our model #et21pkxgwol wirlpool refrig. what causes this?
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jan 13, 2011 | Whirlpool Refrigerators
The drain at the center-base of the freezer freezes shut with ice. Water accumulates on the frig shelves and under the veg bins. Why and what to do? Frig is a Whirlpool 21 cu-ft ET1CHMXKB03 built in 2004.
There is supposed to be a defrost element that goes through the first part of the drain, it may have been pulled out or it may be malfunctioning. After the evaporator defrost cycle the water should drain through the drain tube, since it's frozen up the water just accumulates in the fridge. If you take off the inside panel that covers the evaporator coils (the coils that freeze up) you should be able to see the evaporator defrost element and the drain defrost element. Inspect the drain defrost element to see if it's in the drain tube like it should be or if it needs to be replaced.
Mar 26, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Defrost tube maybe blocked
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jan 18, 2010 | Whirlpool ET1MHKXM Top Freezer...
There is always water, it freezes in the fridge and then melts everywhere
Oct 12, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
On an intermittent basis I will come home to find a puddle under the refrigerator
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator freezer drains keeps freezing over, not plugged.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 02, 2009 | Refrigerators
About every 2 months the defrost drain gets plugged
Jul 01, 2009 | Whirlpool ET8WTKXK Top Freezer...
Freezer cool but not freezing
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models they don't have the timer but an electronic device which replaces the timer.
Jun 30, 2009 | Frigidaire FRT21S6A Top Freezer...
Sound of Water coming from internal backside of freeze
Your unit was in defrost mode (happens once a day) and ice that built up over the previous 24 hours was melting and draining down a drain line to a pan under the unit so it will evaporate. This is how freezers stay " Frost free ". The water in the pan under the unit will evaporate by itself. Have a great day!
barneyluc
Oct 10, 2008 | Whirlpool ARG930 Compact Refrigerator
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
