Question about Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
DROPPED MY BOSCH 1590EVSK JIGSAW, REPLACED BENT BASE, BUT BLADE IS STILL NOT PERPENDICULAR TO BASE. CAN'T SEE ANY ADJUSTMENT METHOD TO ALIGN BLADE PERPENDICULAR TO BASE PLATE. HELP
    Problem Solver:
  • 19 Answers
The socket-head screw that holds the sole plate on is also the alignment screw. Loosen it a little and the sole plate will swivel left and right. There are graduation marks on the base to help with alignment but I always use a square to verify the alignment. Tighten the screw and check again that it didn't move and you are ready to go.
Posted on Feb 24, 2011
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
My Bosch PST 650 has suddenly stopped working. I have checked the fuse and general things but it still doesn't work. Any Ideas???? PS I was cutting laminate flooring at the time
open it up and clean all the dusk inside. probably it's stuck and can't start the mechanism. That's what i did with mine. Working perfectly again.
Aug 08, 2011 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Blade wonders on straight cut
When doing any straight cut use a straight edged piece of something to run the jig saw along, using as a guide, this will usually keep it all straight, sometimes it can be a loose blade, or a bent shaft?
Mar 08, 2010 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Jul 28, 2009 | Bosch 1581AVSK Top Handle Jig Saw Kit
My 9 month old Bosch 1590 jigsaw will not start??
The problem is the switch, or trigger switch. It may just have saw dust in it or it may be shot. Try blowing the dust out of it with a good blast of compressed air. If you don't have a compressor to do this go to a tire shop. They will help u.
Jun 20, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Bosch 1590EVSK Problem
No safety or reset. The problem is likely to be a bad connection somewhere inside the jigsaw or dust around/inside the trigger assembly. If it is new or recently purchased, seek a replacement. If out of warranty, you could try disassembling it and checking for loose wires, or using an appropriate multi-meter to check where the current is absent and go from there.
Jun 19, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Blade misalignment
The 1590, like several Bosch jigsaws, has a selector switch to choose the type of cutting action. You have to choose the appropriate cutting action, either straight or oscillating, to accommodate the material you cut and the blade you cut with. For instance, if using a very slender blade for clean curved cuts in wood, a slight oscillating motion ( setting II or III) reduces friction on the blade.
If you choose the straight cutting action you get maximum accuracy, but drastically increase the friction because the blade is held firmly to the roller bearing.  A slender blade can handle that for brief periods, (say... less than thirty seconds) in soft, thin wood with a straight cut. In hard woods or engineered wood products ( plywood, MDF etc.) the thin blade will heat up and bend.
You can reduce friction by choosing an oscillating cutting motion, or you can use a larger, sturdier blade. The "Aggressor" blades do not cut as smoothly as the "clean" blades, but they cut faster and are stronger. To cut thick wood ( 4x4 ) or a long cut in engineered material, that is the blade I use. Select number III or number II for 'type-of-cut' and use a bigger blade. See if that stops the "bucking."
Mar 24, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw Logo
289 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
