Question about GE 24 in. GSD530X Built-in Dishwasher
Dishwasher doesn't seem to be cleaning very well. Washtower is just sitting in place - should this be connected?. I found a pices of stainless steel wire in the bottom of the dishwasher - what was this ? How can i tell if washtower is functioning properly? Model GSD5630
    Genius:
  • 1,075 Answers
Where do i start?first you tell me its not cleaning very well then you say, does it need connected im really confused.If its not connected then it will not work at all,the first thing is to get someone to check it becaues it should be pluged in and plumed in,ie water and electricaty.adrian,,,,,,,,,,,,
Posted on Aug 20, 2010
  • GE Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Tip
Gasket cleaning: Start by noting where angled ends of thick black gasket sit....
Gasket cleaning: Start by noting where angled ends of thick black gasket sit. Pull gasket out of stainless steel gutter. Soak and scrub with dishsoap in the sink. Start by placing one angled end as noted earlier. Press gasket firmly back into gutter.
I am really happy with Bosch for making it easy to clean!
on Feb 01, 2014 | Bosch 24 in. SHE66C05UC Stainless Steel...
Only a small amount of water comes into the dishwasher and doesn't seem to spray or wash the dishes. It's a whirlpool quiet partner 4 dishwasher.
There are 2 possible things causing that
1) the water inlet valve is bad and not fully opening to let in enough water
2)water pressure to that inlet valve is restricted,that could be from if it uses a stainless steel flex hose,something under the sink has pinched it perhaps .
To check turn off water remove line where it connects to dishwasher place end in bucket and turn water supply back on...if pressure good the valve needs being replaced
Reply back with actual model number as found off of label on door rim and i'll give ya part number
Aug 23, 2011 | Whirlpool Dishwashers
New dishwasher...The Rinse Aid doesn't seem to be putting out any liquid. (How is it supposed to work?) Plus, dishes don't seem to be coming out as clean as expected. In your opinion what is the...
You won't see any liquid it comes out and gets rinsed off during the last wash cycle.As for detergant I think your best bet is to use the tablets. Like the three and one "Finnish " Hope this helps.
Jun 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Washtower won't raise
Check water pressure. Water pump. contact service center for assistance.
May 02, 2010 | GE GSD2200G Built-in Dishwasher
Is there a product on the market that I can use to clean the inside of my Maytag dishwasher? We have very had water and there seems to be a hard crusty film build up inside. The dishes are not as clean aas...
Hello
I have used Vinegar myself.
just placed a large cup full in the top rack and ran it through with no dishes in the dish washer.
and once the dishwasher was clean we used a small amount of vinegar to clean the stainless steel bowls and silverware and glass.
I have also used this product:
http://www.reliableparts.com/product/Glisten-Dishwasher-Cleaner-1476390/Dishwasher-Accessories-461418
and it also worked..... although there are restrictions ( no stainless steel dishwasher tubs ).
I found this site for you:
http://www.mrscleanusa.com/tips/clean-dishwasher.html
I found this product for you as a bonus although I have no personal experience with it
http://www.smallwonder.info/?gclid=COyUycvLgaACFQwNDQodKm_Zjw
Feb 20, 2010 | Maytag Dishwashers
Cleaned inside then ran a vinegar solution through,seemed to be working fine then started running with no water/?
Have no fear about the vinegar causing the water to stop working. It is not directly related and the problem would have happened at some other time soon.
The most common problem with water not entering the dishwasher is a failed (hot) water inlet valve (solinoid valve) That valve can be found by following the hot water hose to the dishwasher. At the place where the hose connects to the dishwasher you will find the valve.
Good Luck!
Feb 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
GE 24 in. GSD530X Built-in Dishwasher Logo
119 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
