Question about Singer 8280 Mechanical Sewing Machine
Top thread isnt picking up the bobbin thread. when i crank the wheel counter clockwise the top thread actually wraps around the bobbin case. what am i doin wrong? im a first timer.
    Genius:
  • 1,788 Answers
Use a fresh needle and make sure that you place the flat side to the rear when you insert it. Use a coin to turn the needle screw. Also, get a free downloaded manual from www.singerco.com
Posted on Aug 21, 2010
Singer 328 is not stiching
if upper thread correct, check bobbin is wound and inserted correctly. Pulling bobbin thread, the bobbin should turn counter clockwise. make sure thread is under bobbin case tension spring. With cover plate open hold needle thread and turn hand wheel towards you to see if hook picks up needle thread and passes it around bobbin case. if not check hook timing
Jan 05, 2014 | Sewing Machines
I can only get a small amount of thread wound on the bobbin.It stops and wont take any more. The bobbin case keeps moving & I cant get it back in correct place
I assume you are placing the bobbin at the TOP of the machine, then wrapping the end of the thread several times around the bobbin in a counter-clockwise motion?
Have you made sure to "scoot" the empty bobbin next to the bobbin bar to the right? Is the thread going from your spool, directly TO the bobbin? Because it is supposed to wrap around the tension "nut" (where you start to thread your machine) before going to the bobbin.
Apr 24, 2010 | Brother XL-2230 Mechanical Sewing Machine
How do i thread my bobbin on my singer merritt 4530
Run the thread around the little silver knob on the top of the machine to the bobbin threader on the top right. Wrap the thread clockwise around the bobbin a few times and then pull the bobbin threader toward the silver bar. If you put your hand on the crank wheel, you will feel a place for your finger to set. Push there and the center of the crank wheel will sideways allowing you to thread the bobbin when you press the pedal. I'm sure my terminology doesn't make any sense.
Jul 11, 2009 | Singer 7462 Mechanical Sewing Machine
Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Jun 30, 2009 | Sewing Machines
Want pick up my bobbin
re-thread the top thread
when putting in the bobbin, make sure you put it in right,
hold the bobbin between you thumb and first finger of your right hand when you pull the thread with left hand it should rotate the bobbin counter clockwise.
If you run your machine all day you need to clean under the bobbin case,
Take the cover plate off, take out the bobbin case and clean under, i take a q-tip with machine oil and rub around the inside of the metal case and around the bobbin case,
replace the plastic bobbin case making sure it's in right, turn the hand wheel by hand, the case should stay still and the inside will move, the needle should not hit anything
put all back together and try again
if the bobbin turns clockwise you are going to have problems
if this helps please rate it
thanks,
good luck
moni
May 09, 2009 | White Sewing White 4400 Computerized...
How do you thread a kenmore sewing machine I can't figure out how to thread the bobbin for kenmore machine 1385.15343600.  I am a beginner, so I will need pretty detailed instructions. Thanks! Jenny
Put the bobbin on the short metal stick on top of the machine. Unthread the machine. Put the spool of thread on the tall, left side stick on top of the machine. Take the thread and wrap it counter clockwise around the circular, short, metal thing on the left side of the top of the machine, only 180 degrees. Thread the thread through the hole in the bobbin (which should be on top). Press the bobbin to the right, into the little white thing. Pull the turning wheel on the right side of the machine out. While holding the end of the thread, softly press the presser foot so that the thread goes around the bobbin a few times. After that, cut the end down to the bobbin. Now, press the presser foot down and wind the bobbin until it stops on it's own.
Mar 05, 2009 | Kenmore 15343
Singer 600 touch and sew
Hold the tail of the needle thread loosely.
Turn the hand wheel toward you (counter clockwise) and lowerthe needle into the hole in the plate.
Turn the hand wheel until the needle rises back up to it's highest position.
Gen
You will see a loop of thread wrapped around the upper thread.
Open the loop and find the free end of the bobbin thread.
Voila!
Now you can sew.
Oct 23, 2008 | Singer 3116 Simple
Threading a Bernina 900
Place the thread spool on one of the two thread guides. Bring the thread across to the notch on top of the machine guide it to the left and down the front of the machine. Directly under that threader close to the needle wrap it down under and go back to the top right to left then go to the top lever in the up position use your wheel to the right , wrap from right to left going down and threading. Wrapping just means placing around. Now for the bobbin. take casing out wit bobbin thread counter clockwise place in casing and release handle of casing put in machine making sue it is locked in. THen go fishing.
Sep 22, 2008 | Bernina 1008
How to properly thread the bobbin
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Sep 21, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Singer 8280 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
