Question about Haier hwr10xc6 Air Conditioner
ALGEA AND WATER HAVE BUILT UP INSIDE AIR CONDITIONER - HOW TO GET OF IT
  • Haier Master
  • 43,501 Answers
Spray everything down with a clorox and water solution in a spray bottle. Mix 1 part clorox to 10 parts water. Then place a few ounces os clorox in the water in the drain pan. Many window a/c units are leaving water in the pan and using it to help cool the condenser coil now. Not really a great idea in my opinion.
heatman101
Posted on Aug 20, 2010
The air that comes out of the vent stinks. How do i fix this? Do i need replacement parts? Please help...
No you probably don't need any parts just a thourough cleaning of the water tray and evaperator coils and the air filters. they make a product you can get at hardware stores for cleaning the coils and a mild detergent and water with a little baking soda should clean the rest. you will need to dissasemble the unit for the cleaning so as not to miss anything. Over time water builds up deposits and they can grow algea's and molds that cause these smells. You might however need to replace the filters if yours are not washable or are damaged beyond cleaning. Refer to your manual on the cleaning process.
Sep 09, 2011 | Danby Portable Air Conditioner
Air conditioner leaked a lot of fluid that looked like water after being on all night. Do you think this is an easy fix, or what do you think is wrong with it? Thanks
All air conditioning units have built in drains. When the drain is clogged the water fills the drip pain and spills out. An easy fix is to open you unit and just wipe the drains. If you cannot find the drain find where the water is coming from and trace the water to the source. The other possibility is that the unit has a dehumidifier that is not properly sealed and it is leaking the water it collects if so find the dehumidifier (usually labeled) and pull the cover off clean the seal and put cover back on (may snap into place) and see what happens the next day.
Aug 21, 2011 | DeLonghi PACA110 Portable Air Conditioner
My Duo Therm Part # 3106481 about 10 years old cools okay but puts water in the duct system.
It sounds like either the condesate drain pan has a leak in it or more likely the drain outlet is plugged. Take the cover off the unit to where you can see the drain pan and if it is full of water then uou can try to blow it out with air or run a small diameter wire thru it. If you can get it open then clean coils as well as you can and pour a quart of water into the pan that has about a 1/4 cup of bleach mixed in with it. The bleach will kill off algea and other substances that may be plugging the drain. Thank you and good luck.
Jul 01, 2011 | Dometic Rooftop RV Air Conditioner
My coleman rv ac unit is dripping condensation inside the camper, what is causing that?
It is possible that the drain hole on condensate pan is plugged and causing water to over flow pan. Remove cover from unit and check drain line.Clean coils andpan as best you can and clear drain hole. Add a small amount of bleach to water in drain pan.This will kill any algea or bacteria that may be growing in condensate water and plugging the drain. Thank you
Jun 20, 2011 | Coleman Mach III Air Conditioner
My attic Goodman Air Conditioning unit is leaking down through the ceiling drywall. What are some of the possible problems and how do I fix them?
Ours did that. It was low on freon causing ice to form on the unit in the attic. The ice would melt causing the leaking down the drywall. We had a hvac rep. add freon. Cost will depend on how much is needed - we spent about $100. Afterward, we touched the spot on the wall up with Kilz & matched up with leftover paint in the shed. Good as new!
Jul 18, 2010 | Goodman CKL60AR60 Air Conditioner
Water builds up in pan and theres no hole for it to come out of.. i have it sloping downwards. why is that?
The slinger blade (condenser blade) picks up water in the bottom and that helps cool off the freon. It is a built-in design. If water is coming inside the house tilt the ac downwards towards the backside so that the water can drip outside.
May 25, 2010 | Whirlpool ACE244XS Air Conditioner
Water dispenser has algea inside the water tube
Clean out the water container by using Muratc acid(mild HCl) by mixing 2 parts water & 1 part acid. Let it stay for 10 mins then drain and flush with good clean water............sodeep
Jun 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking, and i need users manual..can yu help me pleas..
If its leaking water you have a drian problem. Look at the white 3/4" line, get a coupling frst then cut. you can use air but in most cases you can just blow the algea through. Reconnect and so on...
Mar 31, 2009 | Carrier 38CKC036 Air Conditioner
Split HVAC does not achieve requested temperature
If is heating on outside temp must bee max 5 degree
Celsius.If leak inside unit then check drain hose.
Feb 15, 2009 | Mitsubishi MS-A09WA Split System Air...
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Haier hwr10xc6 Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
