Question about Dryers
I have a Kenmore Dryer, Model # 110.64952300. It will start, heat, and turn for about 20 minutes. Then it blows the fuses in the fuse box, stops heating, but keeps turning. Can you help me figure out if it is the thermostat inside the dryer and how to fix that? Thanks!
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I would check the heating element...it probably shorts out once it gets hot and then touches metal that shorts it out...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
The timer will not advance, it heats up on the correct settings, but will just stay on indefinately. Sounds like a classic Timer issue, but just want to ask for a second opinion, and ask what the part...
We have a dryer ( could be any make! ) that is consistently blowing fuses after about 15-20 minutes. We have taken the dryer apart to check for clogs in the venting system and to check if the heating core was okay and they seem to be fine. Any ideas?
Blowing the house fuses? If yes....the dryer usually will blow a fuse right away if there is a problem in the dryer....more often than not a fuse that blows after the dryer has been running a while it is a fuse box issue. A test: Put 2 new 30 amp fuses in and run the dryer with the heat on for 5-10 minutes, turn off the dryer and quickly remove the fuses from the house fuse box and see if they are hot at all ( especially on the bottom )....if the fuses are getting hot they are probably melting the fuse link and not really blowing = fuse box problem.
As for most things there are exceptions....a grounded heating element -may- blow the fuse after the dryer has been on for a while, it is easy to test for that as well. See. A burnt/loose power cord/plug -may- also give this type of a problem.
Dryer basics- Venting problems and power supply:
Most dryer "to long to dry" or "poor/low heat" complaints can be traced back to a bad or poor venting system and sometimes a poorly maintained lint filter. Do not go outside and put your hand under the vent opening and say " it is fine - I feel air coming out"...that is not good enough...take your venting apart, clean it ALL out and make sure the vent hood flapper works and that it is not clogged with lint. Make sure your venting system is short, straight and resistance free as possible. A poor venting system will shorten the life of your dryer, plug up the fan blower and duct work inside your dryer as well.
Gas dryers need 120 volts to operate the whole dryer. Electric dryers need 240 volts to operate the heating element and 120 volts to operate the timer and motor. You should see 240 volts between the black and red wires, 120 volts between the red and white wires, 120 volts between the black and white wires at the electric dryer main power harness. A blown house fuse ( or breaker ) would stop a gas dryer from working at all. A blown house fuse ( or a 1/2 tripped breaker ) would still allow the electric dryer to run but you would get no heat. Depending on which fuse goes, sometimes the dryer could be dead as well. If you have problems with a fuse letting go or a breaker tripping after the dryer runs for a while, normally the problem is not in the dryer but is in the fuse box.i think it will work
Dec 16, 2010 | Dryers
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
What will cause the thermal fuse to continually blow.
shorted motor or heating element, which causes excessive current draw would be the cause, replace the heating element first.
Aug 28, 2009 | Kenmore 63942 Dryer
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
Dryer won't heat
I know you said the fuse box is fine but check and see if you have 220 volts at the dryer cord we need to start there let me know what you find
bill
Jan 10, 2009 | Dryers
KENMORE 80 SERIES NOT HEATING
you need to check the heating element and the thermal fuse in the back of the dryer, they should be their. do you have an ohme meter, if not barrow one or you can pick one up cheep and lowes or homedepo .
Dec 13, 2008 | Kenmore 659 Electric Dryer
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
143 people viewed this question
Top Dryers Experts
