Question about Sub-Zero 632 / S
What pressures should the refrigerator read.. 134a
  • Sub-Zero Master
  • 43,501 Answers
With refrigeration pressures that will vary greatly with the temperature.
When downn to proper cool temperatures the low will be around 10-15 and the high side 150 or so
heatman101
Posted on Aug 20, 2010
Testimonial: "i want to thank u very much for your time. thank you, paulie"
134a pressure
134a is a refrigerant...
Different type of dryer. The picture totally threw me at first.
http://www.ingersollrandproducts.com/am-en/products/air/compressed-air-treatment/non-cycling-refrigerated-dryers
Mar 09, 2014 | Ingersoll Rand Dryers
134a american gas
Refrigerant HFC-134a or R134a
Weight 330 - 390 gms
With correct refrigerant:
Low side pressure 1.5-2.5 kg/cm2
High side pressure 14-16 kg/cm2
Sep 19, 2013 | 2011 Toyota Yaris
What are the AC pressures supposed to be on a 2000 Monte Carlo?
On hot day @ 85=+ degrees it should be between 45 to 50 pounds on the low side pressure port
Jul 01, 2011 | 2000 Chevrolet Monte Carlo
My 1993 cadillac deville A/C is not blowing cold air in fact it switches to ECONO soon as I turn the A/C on, R12 is currently the last refrigerant used does the compressor need to be removed to convert the...
The A/C system is most likely low on refrigerant. A pressure switch will disengage the clutch on the compressor if it drops below a certain point. The compressor will not need to be removed for conversion to 134A. The conversion kits are available at most automotive retailers in addition to leak detecting and fixing agents which can be introduced into the system. It is very important to identify the low pressure access point in order to use these products and read all the safety warnings before attempting this on your own.
May 04, 2011 | 1993 Cadillac DeVille
R-22 refrigeRATOR OPERATING PRESSURES
google refrigeration pressure temperature chart
Jan 22, 2010 | Traulsen Commercial 2 Door Cooler /...
Have 134a refrigerant and shop where I bought it said owners manual will have the how to instructions. Unfortunately it doesn't. I see on the line there is a stem to screw the hose into but want to make...
No,you won't find it in the owner's manual. It charges through the low pressure side,which is the larger of the 2 available ports. You can't hook it up wrong. I suggest you buy a Hayne's manual for the truck. It has 90% of any answer you might need. A/C can be tricky to fix for the novice. If charging doesn't work,take it to the shop.
Jul 13, 2009 | 2001 Dodge Durango
1999 beetle AC... Ac works maybe 1 in 10 times for about 10 minutes then stops. Checked 134a level (good)... When AC is turned on, aux fan turns on, clutch engages on compressor and 134a pressure drops...
check ac and let car get hot(not overheated) and with guages on high side is it above normal? 2.75-300 or more? this would be the problem ac cutting out cause ther is a problem some where u need to use ac gauges it will tell the story
Jun 30, 2009 | Heating & Cooling
Recharge air on a 1998 oldsmobile bravada
You didnt actually post a question so I will try to help. You need 134a refrigerant and a way to get it into the system. Places like walmart and Advance Auto Parts has what you need. Most diy kits have a hose to connect to the Low Pressure side of the ac system and a guage. The other end of the guage has a connector that fits on the can of 134a. Start the car, turn the ac on high, open the hood. Being careful of moving parts under the hood, connect the hose to the Low Pressure side of the ac and see where the guage is reading. Most are color coded. If it says it needs charged, squeeze the trigger until the can is empty and take another reading. Continue until the guage is in normal range.
Jun 23, 2009 | 1998 Oldsmobile Bravada
Operating pressures for 134A refrigerant system
I would go for 40 on the suction and 150 discharge, or divide the locked rotor current by 6 and charge so the current is 1/6 of the locked rotor current of the compressor, or by temperature/pressure relation 110* discharge and 35* suction, or get the suction line sweating. The best way is to remove all the refrigerant and then weigh the refrigerant the system is designed for on these critical charge appliances.
May 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Recharge Refrigerant 134A into Fridge
get a pericing valve from your local appliance parts store 25 inch and put it on the small little what i like to call pig tail make sure your pluged up and running when you do this .go get a can of 134a from autoparts store best one is advance autoparts get a car ac switch over kit from r12 to 134a and in it will be a fitting that will fit your pircing valve then read instructions from their .GOOD LUCK !!!!
Jan 02, 2008 | Refrigerators
Sub-Zero 632 / S Logo
730 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
