Question about Amana Heating & Cooling
When i put on d ac, d compressor will work for d first 10mins and afterwards it will stop working and blows fan only.after 6mins it will come on again and will only work for just 3mins afterwards b4 breaking and d process continues that way. i need an urgent solution pls.
  • 139 Answers
If this is a window ac depending on how old will need to be cleaned every few years use a garden hose to clean coils a coil cleaner should be used but good water pressure can remove the dirt its gotta be clean first both coils same goes for central a/c
Posted on Aug 20, 2010
03 grand am ac wont blow cold air
Two things are very likely to be your problem. Freon or compressor. Turn on the ac on cold and see if the compressor is engaging, if it is and stops and goes or if it doesn't. try to check the compression on the low side of your ac, the smallest plug where you service the ac. Or take it to an ac professional to get it refilled or checked. Remember, just because its blowing air, it doesn't mean its working. There are fans inside the car that push the cold air inside your vehicle and most of the time these will work, but that's not the only part required to blow cold air inside your car, the compressor is what makes the air cold.
Oct 09, 2014 | Cars & Trucks
My Cadillac 08 CTS will not blow cold air the relay checked out but when I jumped the relay the compressor kicked in and it blew cold air when I put the relay back in I had nothing tried a horn relay...
there are 3 switches that control the operation of the ac compressor . There is a high pressure switch that will not allow operation if the head pressure goes too high ( excessive gas-blocked system-tx valve condenser fan not working )There is a low pressure switch that stops the compressor when the gas has leaked out and is insufficient A thermostat that will not register and so will not switch on the compressor and finally ac compressors will not work unless both the ac switch and the blower are switched on. Have the system checked out by an accredited ac specialists.;l
May 02, 2014 | Cars & Trucks
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
HEIL HVAC, fan blows but no heat or AC
Your airconditioning system may be out of cooling gas, and if it has sufficient gas, the compressor might not pick when you put on the AC, and if the compressor did not pick ie start, you cant experience cooling effect, the fan will only be blowing.
Jan 18, 2013 | Cars & Trucks
Where's the fuse for the AC on 98 Olds 88?
So what does the fuse that blows, protect?
You need a wiring diagram & start to test
the components most likely to cause a high
current draw & blown fuse.
Don't keep replacing it.
You know the fan control circuit works, but the
compressor doesn't stay on. Did you monitor
the compressor as the fuse blew?
May have a module for compressor & fan
If so one side failed
The compressor clutch could be bad
May 24, 2012 | 1998 Oldsmobile Eighty Eight
I have a 97 Toyota Camry. The AC has been working great and gets really cold. Yesterday as I am driving the light on the ac power button starts to blink, after about 45 seconds the ac turns off and stops...
CHECK THE AC AND HEATER CONTROL FUSE.MORE LIKELY FUSE BLOWED BECAUSE AC COMPRESSOR COULD HAVE FAILED IF LOW SIDE IS OVER 100 PSI. THE REED VALVE PLATE IN COMPRESSOR PROBABLY DAMAGED CAUSED COMPRESSOR FAILURE BLOWED THE HVAC CONTROLS FUSE. HAVE AC SHOP CHECK IT OUT.
Aug 29, 2011 | Toyota Camry Cars & Trucks
I have a 2004 2.7 6 chrysler sebring lxi. ac blows really cold and periodically just starts blowing warm air. is there a relay or temp. sensor that might be going out and through a malfunction shuts down...
Cooling fans working? If you notice the air getting warm mostly while stopped, probaby cooling fans not turning on. if the fans are working properly, may be low on freon and need a recharge.
Jun 26, 2010 | 2004 Chrysler Sebring
Ac does not blow cold at idle... ac condenser fan
that seems to be the problem. If the fan does not turn on when the a/c is turned on it could be a fuse, relay, control box, or just a bad fan. Try connecting the fan directly to see if it works. Does this car have 2 fans? normally all the small cars have 2 fans one for the engine cooling and one to assist the first when the a/c is turned on. Without the fan pulling air through the a/c condensor the had pressure goes up high enough to shut off the a/c compressor. It also causes some cars to run warmer than usual when stopped. Check the a/c condensor for blockage also which doesn't have anything to do with your fan not working.
Aug 18, 2009 | Volkswagen Passat Cars & Trucks
2002 Honda Civic A/C not working
high and low pressure swich try putting freon in it
Aug 12, 2009 | 2002 Honda Civic
2000 jimmy a/c blows hot computer controlled a/c button light was blue when working now yellow and blowing hot just charged system no change
check to see if ac compressor is turning ,if so look to see if cooling fan/fans are working if not check fuses,and cooling fan relays/if ac is turning and cooling fan/fans are working ,need to put gauges on ac system and check pressures ,if normal ,and ac low side pipe/lines/hoses are cols then it is ur actuator motor for the temp door that is not working
Jul 08, 2009 | 2000 GMC Jimmy
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
