Question about Maytag Neptune MDG5500AW Gas Dryer
We installed a new control board on a maytag neptune dryer MDE5500ayw. everything is installed correctly but the dryer will not start. The lights are on and there is no fault showing. How do we reset the dryer?
  • Maytag Master
  • 2,696 Answers
Are you positive it was the board and not something else wrong?check to see if you have power to the motor with a meter,if you do you have a bad motor,also check the thermal fuse.you need to get in there with a meter and check things out
Posted on Aug 20, 2010
  • Sal De Aug 20, 2010
    also i looked up your model number and that dryer is electric,not gas
    i looked up the number you typed in, mde is electric but the other number is MDG5500AW,you must have just typed the wrong letter.try unpluging the dryer for 5 to 10 minutes to see if it resets the board,if it doesn't with a meter check the motor and the thermal fuse,good luck
Why won't my maytag neptune dryer start?
circuit breaker timer control board door switch . to name a few posabilities I would call a service man
Mar 15, 2015 | Maytag Dryers
Maytag dyer problems
it sounds like the control board is going bad but i wouldn't buy any parts for this dryer,soon you won't be able to get parts for it,put the money into a new dryer not to mention that the neptune products is what took maytag out and now whirlpool owns maytag.you could also have a problem with one of the connections or a bad wire in one of the connections and when you move the wires it's working again and this could be from the heat,after years the wires get brittle,you could buy the new board,put it in and if it's a wire you're back to square one,but from what you say it's either a wire in one of the connections or the board.good luck with your dryer.
Nov 12, 2013 | Maytag MDE5500AYW Electric Dryer
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mde5500ayw dryer had an oversurge of power earlier, now dryer display is dead but light inside is on. Is there a fuse in dryer?
could be one on the control board, but I will bet if you had an electrical surge theres more than just a fuse gone
Oct 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Model MDE5500AYW Maytag Neptune Dryer showing code 8.8 and won's start
the circuit in the control. you can get it at
http://www.apwagner.com/index.php?main_page=part_finder
I hope this helps.
Dec 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
180 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
