Question about Lasko 2551 Air Purifier
My lasko 2551 will oscillate, but it won't blow air
Lasko ceramic heater how to clean
Blow compressed air through the front of the heater and then vacuum the back of the heater. That shouild do the trick but take note that there appears to also be a switch that detects if the unit is tipped over. With the heater in the upright position you may also need to lightly bang the unit on its bottom before the it will start to run again.
Oct 17, 2013 | Air Purifiers
Lasko blower fantype DTB E20739 PM7331
to clean your fan from dust
Jul 02, 2013 | Air Purifiers
Ceramic heater only blow cool air
Unplug the unit and look on the bottom or the back, there may be a circuit breaker reset switch.
If not, it's probably a fuse that's blown inside the unit and isn't made to be replaced.
Sep 24, 2012 | Lasko 6405 Designer Series Osc. Ceramic...
I have a 42" wind
the first thing to check is that the remote control is working and the control panel of the fan itself are working probably and i think they did but you have to check first
this fan oscillating control button is not a mechanical connection like the regular fan so if you are not using it wrong(and i think you don`t ) an if all the buttons are working -except the oscillating function - (and i think they are ) turn that thing back and test it at the shop
May 22, 2011 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
My Lasko 42" Wind Curve fan when I plug it don't power up. Pluged at diferents outlets, same results Thank you
Check out the cord, (frayed or broken) usually right where it enters the unit, and the switch.... if these check out then the motor has gone bad...
heatman101
Aug 18, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
It won't blow air.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 14, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
How do you clean the ionizer in a lasko wind curve
You have to take the fan apart. They didn't design it with the convenience of the customer who likes to keep things clean in mind, so you have to get out a bunch of screwdrivers and stuff and roll around on the ground and fight with it until you get it apart. I posted a lengthy post on how to get this model apart, as I just did mine yesterday. Just look for my name on the Lasko models like this one. But be careful and don't try it if you don't think you can pull it off without getting hurt.
Jun 11, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
How to clean my Lasko 42 Wind Curve Platinum?
Yep... ALL the screws in the back mus come out as well as the base. The only real problem I had was that 2 of the screws were randomly triangle drivers instead of phillips/straight combo. Ya know they do it just to tick you off...
Nov 02, 2009 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
How do i clean a lasko tower fan model 2551 as it is dusty inside
best is if you have an air compressor and blow it out, if not, a paintbrush and vacuum will do. remove grill/cover if you have to. make sure unit is un plugged.
Sep 06, 2009 | Air Purifiers
Lasko 2551 Air Purifier Logo
93 people viewed this question
Top Lasko Air Purifiers Experts
Tom Chichester
Vignesh
Vignesh
Level 1 Expert
Are you a Lasko Air Purifier Expert? Answer questions, earn points and help others
