Question about Metra Ford/Chry/Jeep 1974 99
Metra 70-1002 wiring diagram - Metra Ford/Chry/Jeep 1974 99
Wiring wiper swicth diagram
OK
  1. google your make modal and year as well as wiper switch wiring diagram
  2. when page opens look across the top and click on images
  3. when the page opens Pick your wiring diagram and click on it.
  4. when open click on visit page.
  5. and there it is
Mike
Mar 23, 2016 | Metra Chevy Truck 88 94
Metra wiring diagrams 70-1761
I believe that the orange dimmer wire should not be connected to anything. I taped my orange wire and left it unconnected and it worked.
Dec 13, 2013 | Pioneer FH-X700BT Double-DIN Car Stereo...
Need Toyota wiring diagram for Radio Model 86120-04090
truble i get a radiocassete model 86120-02071 need the wiring power o aoutput spekers diagram
Dec 23, 2009 | Metra Toyota Lead To Oem Radio 94 87
Stereo diagram for 1990 geo prizm
Hello stoogieprezi,
You should have gotten a plug-in harness with your new Alpine. To avoid cutting or tapping the wires on your vehicle, you need to purchase an aftermarket wiring harness. It appears that the Metra 70-1782 is the correct one for the 1990 Prizm.
Then you simply match up the wires on your Alpine harness with the Metra harness. The wiring color code for the harness is shown on the bottom left of the "description" tab and matches up with the Alpine color code on page 18 of your owners manual.
Hope this helps.
Jun 10, 2009 | Alpine CDM-9821 CD Player
Toyota original car audio 75400
You can pick up a Metra reverse harness from most stereo shopes and it will also have the wiring info you need.
Jun 04, 2009 | Metra Toyota Car 1987 2000 *Nic
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
May 21, 2009 | Pioneer DEH-1500 CD Player
Car audio wiring diagram for 1998 volvo s-70
CLICK HERE for your vehicles full service manual. If you are cutting wires.
Be warned your vehicle has a factory amplifier installed, and needs to be bypassed to hear the speakers if you are just wiring behind the dash.
Metra makes a harness you install on the aftermarket radio, then simply plug into the vehicle's harness.
All the wires are labeled for easy installation.
70-9220 is the metra part number. Click on the number to see an eBay auction.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 09, 2009 | 1998 Volvo S70
Metra Ford/Chry/Jeep 1974 99 Logo
53 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
