Question about Maytag MAH6700AWW Neptune Front-Load Washer
New washer computerized- was loaded and start button pressed is flashing 'dL' and wont begin wash
  • 712 Answers
If its new, never try to repair it yourself. Instead report this to your dealer if you are inside the warranty period.
Posted on Aug 20, 2010
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
When I hold the button for it to start it clicks and starts flashing F then dL It will not start washing
The "f" part is saying that you have a fault, and the "dL" part indicates that your control panel thinks that there is an issue with your door lock. The brain will attempt to lock the door six times, then flash the error code. Press pause/cancel twice to clear the alarm. Then check your lock. Usually, it's something loose on the lock or catch; it can be the wiring to the lock being loose, or the control panel may have a fault. Start with the lock, and work back to the control panel.
Best regards, --W/D--
Aug 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore Elite front loader HE3 washer will not start.
The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
Eric
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
When pressing the start button a "DL" indicator flashes and then a "F" indicator remains, door does not lock and the washer will not start.
that is the code for door lock. ensure its not stuck or something in rubber boot stopping door from closing all the way and try to reset it.
maybe by unplugging it for a coupkle of minutes
May 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer wont start
the dl code means door lock ,,,, you will need to replace the door latch assy to fix it / larryyb
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Error F dL?
remove the top cover of washer at rear is the main control bd try wiggling the wires on front side usuually the larger wires if it works bad connections on control no fix but to replace it ..HOWEVER try shimming the plugs in place to hold them in position where it will work...possible door lock itself but control more likely
Sep 06, 2008 | Kenmore 46462 Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
