Question about Sony VPL PX31 Multimedia Projector
I have a Sony VPL-PX31 LCD projector. The lamp cover light flashes, then remains lit after powering it on. I suspect the push button safety switch is non respondent. Is it possible to bypass the lamp cover switch?
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
Marrie
  • 563 Answers
SOURCE: Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
Posted on Mar 26, 2008
SOURCE: Sony LCD Projector - burned prisms
I have the same projector, but my problem is with red.
A replacement prism assembly is about $2k.
If you can get your hands on another projector for cheap, that's your only hope. You can swap out the blue lcd panel from your prism with someone else... it's a bit of mucking around, but worth it of you can.
Posted on Feb 27, 2009
  • 4234 Answers
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
Need to reset lamp hours on sony vpl px31
1,Connect the power cord
2,The On/Standy light is red.
3,Press the following keys on the Remote Commander or on the projector in the following order for less than 5 seconds :Reset,left,right,enter.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jun 29, 2014 | Sony Replacement Lamp for VPL PX21, VPL...
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
I have purchased 2 sony ex3 lcd projectors(one for spares,and one that needed a new lamp)I also have a new lamp!!But it wont work on either machines.All i get is flashing on/off light,then lamp cover...
you may have to reset the lamp hour meter to get it to work, put the projector on stanby and press the remote buttons, reset - back - forward - reset, (this is the code for a vpl hs20 projector it may be slighty different for your model)
Jan 14, 2011 | Sony VPL-EX3 LCD Projector
Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
Lamp/cover light flashes
Did you replaced lamp in projector? if yes, please make sure lamp cover is fixed properly on its position. There is safety switch under lamp cover that needs to be pressed to turn off lamp cover light flash.
Thanks.
Oct 21, 2009 | Sony VPL PX31 Multimedia Projector
Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
Jan 15, 2008 | Sony VPL CS5 Multimedia Projector
Sony VPL PX31 Multimedia Projector Logo
101 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
