Question about Carrier BCA101R Air Conditioner
Have an old carrier package unit. Bought it used so unhooked. Want to know how to wire it back up to power and thermostat. Below is not my model, it is 50mh024340c
5 Suggested Answers
SOURCE: Carrier Thermostat Model TSTATCCPB501 ER code
I gave up and called a local HVAC business. This thermostat is discontinued and a new one will be purchased and installed.
Posted on Dec 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: Replace thermostat
Typical color codes in Florida are;
white to W1 for heat
yellow to Y for compressor
red to R-RC-RH for power in
brown to W2 and or emergency /auxillary heat
green to G or Fan
orange to reversing valve(o/b)
blue to common.
You can open the control panel on the unit to verify these colors and components.
Posted on Feb 21, 2009
farfield
  • 462 Answers
SOURCE: need wiring diagram for 1980's 3 ton package unit
I assume you know if this is correct voltage and single or 3 phase, and whether it will fit your application or not, how is the duct work going to attach, how many people will be in the conditioned area, what is the building made of, how much insulation is has...
A little more to it than just "turn it on".
If you get the models and serial and can contact the manufacturer or their representative you might get a wire diagram. Most any package unit would do. As long as you keep the original equipment controls. If you "patch" it up it may be hazardous by not having safety's where it was designed for. Or for instance It may have a anti freeze thermostat. By passing this could lead to coil freeze up and compressor damage. Leaving out a pressure switch (if any) may do the same or could become dangerous to people in the event of fan motor failure. A low temperature fan speed switch may not be needed now unless you plan to run the AC in below 55'f.
And a few dozen other factors that might need to be considered.
If you feel confident after this then contact carrier.
Please rate me as high as you can and thanks for using fixya.
Posted on May 19, 2009
shastalaker7
  • 1515 Answers
SOURCE: Anyone have the service/installation manual for
HI, THE 351 ON THE MODEL NUMBER SHOWS NOTHING. BUT THE REST IS CORRECT. IF THIS IS A HEAT PUMP, IT WILL HAVE MANY MORE CONTROL WIRES. IF YOU ARE BLOWING THE CONTROL FUSE YOU HAVE A DEAD SHORT. GO TO THE OUTDOOR UNIT AND WRITE DOWN THE COLOR AND AMOUNT OF WIRES COMING OUT OF THE UNIT, AND WHAT COLOR THEY ARE CONNECTED TO. THESE GO BACK TO THE INDOOR UNIT. RED IS ALWAYS YOUR HOT, Y IS FOR COOLING, G IS FOR FAN, AND W IS FOR HEATING. IF YOU HAVE ORANGE, BROWN, PURPLE BLACK AND SO ON COMING FROM THE OUTDOOR UNIT, YOU HAVE A HEAT PUMP. ON A SIMPLE CENTRAL UNIT, ONLY 2 WIRES TO THE OUTDOOR UNIT, RED AND WHITE. RED TO RED, WHITE TO Y ON THE INDOOR UNIT. LOOK AT THE SCHEMATIC ON THE INDOOR AND OUTDOOR UNIT, AND IT WILL SHOW YOU WHAT COLOR GOES WHERE, JUST LOOK AT THE LEGEND FOR THE LOW VOLTAGE CONNECTIONS AND THERMOSTAT, AND FOLLOW IT. YOU WILL NOT NEED ANY MANUAL. MAKE SURE YOUR RED WIRE IS NOT TOUCHING METAL ANYWHERE. KEEP ME POSTED ON THE OUT COME, WE WILL HAVE UP UP AND RUNNING. LET ME KNOW IF YOU HAVE A HEAT PUMP.
SHASTALAKER7
A/C AND HEATING CONTRACTOR
Posted on Mar 16, 2011
I am replacing the thermostat with the Ecobee3 lite smart thermostat. The thermostat did not power up. My A/C unit is a Carrier model 40AQ030300BB. Might I have popped a fuse or something?
yes you likely blew the fuse. it is likely a blade style/ similar to one in a car, located on a circuit board inside the blower compartment. BE SURE TO TURN POWER OFF AND LOCATE AND REPLACE WITH SAME THING!!
Nov 11, 2017 | Carrier Heating & Cooling
Have a Carrier Electric Furnace & AC, Model #FA4CNF048 and need to know how to connect a Blue wire to power to supply C wire for new Honeywell Wi-Fi thermostat. Any Suggestions?
C is common for 24 volts from the a/c transformer secondary or low side. R and C are 24 volts and will power up loads of 24 volts such as thermostats requiring to be powered up,
C is usually grounded or connected to the metal of the a-c unit. Use any color available to connect the wi-fi thermostat C to the a-c C to deliver 24 volts to the thermostat.
Jul 06, 2015 | Carrier Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
I ned the thermostat manual or at least a HOW to program it. I have a 48 GS 10 seer 80 AFUE gas package unit with Carrier digital thermostat TSTATCCNAC01-B if their are additional manuals on the unit...
carrier.com has the books look for the 48GS060 not the GX model thes units replced the SS and SX models in 97also the t-stats will be in accessories
Mar 05, 2011 | Heating & Cooling
My Carrier thermostat keeps running my heater. I adjusted the temp lower but it didn't stop running. I changed the mode to off and then it stopped. However, the mode button was insensitive and I had to...
sounds like that thermostat has reached the end of the road. My advice is to replace the thermostat because its 6yrs old and is worn out due to continued use. programmable t-stats have a wide price range to meet your needs. and the batteries in a thermostat are only for back-up power because the thermostat runs off of a 24volt power supply from the air handler.
Nov 28, 2010 | Carrier Heating & Cooling
Wiring instructions for Thermostat Honeywell with Carrier Package
Jumper R to Rc and hook hot wire from transformer to R usually red wire
O = Reversing valve probably white or orange If you get heat when calling for cool or Vice Versa then switch wire from O to the B terminal.
Y = Contactor usually yellow
G = Blower usally green
Jumper Aux to E need to go to unit and use the wire that goes to your Auxiliary or 2nd stage heat
L = Light if you have this terminal on your unit then hook it up.
C = Common from transformer usually black, if you have this terminal on your unit hook this wire up.
Make sure you go to your unit and only hook these wires up if they go to these locations.
Jan 11, 2010 | Heating & Cooling
Need wiring diagram for 1980's 3 ton package unit
May 19, 2009 | Carrier Heating & Cooling
Ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Aug 31, 2008 | Heating & Cooling
Carrier Natural Gas Furnace/Air Conditioner, Model 518CXX036000MBAA
Is this a package unit??? Or is it inside the home?? How old is the furnace. The first thing to do is axcess the fan and see if it is controlled by a computer or its old enough to have a fan switch. Trace the red wire from the fan mtr that should take you to the fan switch
Dec 01, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier BCA101R Air Conditioner Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
