Question about RCA R52WM24 52" HDTV Projection Television
The color convergence is off. - RCA R52WM24 52" HDTV Projection Television
  • RCA Master
  • 5,138 Answers
Bad Fuse FL231 located on right side of your FBT flyback Transfomer their is 3 of them in a roll ,it will be the one in the middle.
Posted on Aug 20, 2010
Periodic color scrambling - out of focus. Seems as though the different colors separate and get out of focus.
Ur tv is having a convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 50GX30B 50". Rear Projection...
Picture is going into a three d color
Ur tv have a problems known a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?The tv convergence board is dead.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 43FDX15B 43" Rear Projection...
There is a gost and crazy color
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D colors look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must have be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Hitachi 43FDX15B 43" Rear Projection...
Picture is not showing correctly. Color seems like it is going out. For example the color green does not show up as green.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Akai/Samsung DLP tv used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Samsung PCL541R 54" Rear Projection...
Hi.all the color are not alined
Tv have a problems known as a convergence problems,it dead.The tv have colors R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced on the tv convergence board to solved the tv picture convergence problems.
Oct 13, 2010 | Sony KP-65WS500 65" Rear Projection...
The red and blue colors are way off i tried to converge adjust the colors no results
Ur tv have convergence problems,it dead.Any colors misaligns,3D pics,shadows pics.The tv convergence board must have it the 2 STK convergence ICS and some or all it resistors are dead,must be change to solved convergence problems.The shop will cost U $300-$350 for parts and labors.
Jun 11, 2010 | Mitsubishi WT-42315 42" TV
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Off colors in picture
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
RCA R52WM24 52" HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
