Question about Texas Instruments TI-83 Plus Calculator
My screen is blue when ever i change my batteries, So I Press the 2nd button and make it lighter. But the pixels dont lighten all the way And when i go to some type of menu like for Zoom, there are horizontal lines that are lighten some of the words and then just black horizontal lines that are there for no reason! Please help...
    Problem Solver:
  • 14 Answers
Try to reset everything to see if that helps. If it doesn't , you can try to upgrade your operating system on the calculator to see if that helps to make it go away.
If that doesn't help try this:
"Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message."
Let me know how it goes.
Posted on Aug 20, 2010
The screen on my TI-89 Titanium turned blue after replacing batteries? How do I fix this? It turns on and off but does not respond to any other buttons.
If you cannot see anything on the screen, you may need to adjust the graphing TI 89 Titanium calculator contrast :
1.To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light.
Sep 01, 2012 | Texas Instruments TI-89 Calculator
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
I just got this calculator and i was looking at the features and the screen suddenly turned black and every pixel is filled in.
It may be that the screen resolution has changed. To change the screen resolution, turn the calculator on, pres the 2nd button and then hold the down arrow. If this is the problem, the screen should lighten up. Similarly, you can darken the screen by using the up arrow.
Jul 15, 2011 | Texas Instruments TI-84 Plus Calculator
New batteries, turned it on and screen is completely black.
First, try adjusting the contrast. Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow for a few seconds and see whether the screen lightens.
If that doesn't do it, remove all four AAA batteries. Press and hold the ON key for at least ten seconds. Replace the batteries.
If that doesn't do it, add a comment here and we'll go from there.
Jun 02, 2010 | Texas Instruments TI-83 Plus Calculator
My screen is to dark to see whats on it. How do i
Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key until the screen lightens. If you go too far, press and release the 2ND key, then press and hold the up-arrow key.
Apr 14, 2010 | Texas Instruments TI-86 Calculator
My ti - 83 hasn't been used in a while, placed new batteries in it and all i get is dark screen.....it won't even turn off......there is just a dark screen......any ideas what causing this and how to fix...
The most probable cause (at least I hope so) is that the screen got too dark after you changed the batteries. It is a common occurrence: Screen becomes too dark or too light.
To adjust the screen contrast:
  1. Press ^2nd key and release it.
  2. Press and HOLD the DownArrow key until screen lightens to your taste.
Mar 09, 2010 | Texas Instruments TI-83 Plus Calculator
When I turn the calculator on, I get a black screen. It won't go away.
Most likely the screen contrast is too high. Try to lighten screen
Press [2nd] key and release it
Press and Hold [DownArrow] until screen lightens to your liking.
As you keep pressing DownArrow, the top right corner shows a number that decreases as the screen lightens.
Dec 15, 2009 | Texas Instruments TI-84 Plus Calculator
The screen is black when I turn it on. I've replaced the batteries and no change. I try to change the contrast and nothing happens. It is a couple years old, but I should still work.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Dec 03, 2009 | Texas Instruments TI-86 Calculator
My ti-84 has a black screen.how do i reset?
Reset by pressing the 2nd button, then the plus button, then 7, then 1, then 2.
Your contrast has been darkened. You can lighten the contrast by pressing the 2nd button then the down arrow key until the screen gets lighter
Jun 03, 2009 | Texas Instruments TI-84 Plus Calculator
TI 85 Screen is too dark
Press the 2nd key and the down arrow to lighten the screen.
Oct 06, 2007 | Texas Instruments TI-85 Calculator
Texas Instruments TI-83 Plus Calculator Logo
160 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
