Question about E-Machines eMachines Desktop PC
So when i power the pc up it says no signal on the monitor and the monitor is good and brand new monitor cord is good
  • 724 Answers
Make sure the monitor cord for the video is properly seated at both monitor and graphics display card end
Posted on Aug 20, 2010
  • tommya300
    tommya300 Aug 20, 2010
    How do you know the monitor is good.
I had an electrical failure and now my pc does not re-boot what can I do?
Posted on Sep 11, 2010
  • 3,153 Answers
Ensure it is plugged into the correct display connection on the back and also ensure it is set in the BIOS to display first from the display connection you want to use.
  • Project NOMAD
    Project NOMAD Aug 20, 2010
    How did you get on ?
  • The answers by Project Nomad / bob_computer are to be considered copyright 2011 and property of
    R. Humpleby
    Use without prior "written permission" is no longer allowed.
    This property is no longer shared with Fixya and its associates / affiliates
    It's removal from puplic view is requested
    Reason. account termination.
Monitor just says no signal - brand new computer.
i had the same problem with my PC too ....
the problem was with the RAM ... the signal was not passing through it ... .
if u got 2 RAM'S try using one at a time u will find out the faulty one .....
hope it solves u r prob...
Jul 20, 2011 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
When I disconnected the monitor to hook up to new PC has not power. Too many cords, is there only one connection for this monitor? I may be crazy and have too many cords but don't see a true power cord.
what brand of monitor and how many leads you might be able to get an adapter of some sorts
there should only be two leads power & the vga lead im not sure what don't is i come from the old school of english
hope this helps
Apr 17, 2011 | Computers & Internet
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
Have many bran new hp La1905wg compac monitors with computers. Have powered up and get no signal then monitor says going to sleep. All do the same regardless of what monitor cable is used. What is...
Hello there,
Step 1:
Check all connections make sure everything is connected correctly .
The monitor should have two cords one for power and one VGA to the PC make sure both are connected correctly.
Step 2:
check the input on the Monitor make sure you are on the correct input for the type of Cord you are using.
Step 3:
If you are still not able to get a Picture try using the Monitor on a different PC it may be a bad Monitor, if you move the monitor to a different PC and it works then its the Graphics Card in that PC that is not working .
if you move the monitor to a different PC and it doesn't work then its the Monitor.
Thank you don't forget to Rate
Jan 25, 2011 | Computers & Internet
CPU ON WITH NO SIGNAL TO MONITOR
Make sure your monitor has power and that the VGA cord or USB cord is properly connected. If your monitor has power (power light is on), disconnect the VGA or USB cord from it, but leave the power on. This will tell you if the monitor is working as it shold display a message like self check or no signal detected and then proceed to display a screen saver. If not then I'd suspect your monitor. If the monitor is ok, then try a different cable between your computer and the monitor. If that fails, then your video card may be defective.
Jan 13, 2011 | HP Compaq Presario SR1211NX (829160534404)...
I have a Gateway monitor that needs a power cord
http://cgi.ebay.com/NEW-12V-2-5A-Adapter-Power-Supply-for-LCD-monitor-Cord_W0QQitemZ220405347970QQcmdZViewItemQQptZBI_Electrical_Equipment_Tools?hash=item33512eb682
Or you can just type in 12v 2.5A LCD Adapter in an Ebay search. You can usually find a bunch of buy now power supplies that come with cords for a decent price. I've been using one of these for a year or so on my monitor.
Nov 14, 2009 | Computers & Internet
Emachines computer problem
have you checked the cord and connection to the video card?also you could try resetting the bios.unplug the power cord on the pc.remove the batterie on the motherboard.power it back up.remove power cord again and replace batterie and restart pc.
Mar 04, 2009 | E-Machines eMachines Desktop PC
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Princeton LCD17 blinks off immediately
Check the VGA cord that connects from the PC to the LCD, try putting VGA cord properly to the LCD and PC, or change the VGA cord. saving mode indicates no signal from the PC. So either the PC is not booting up or VGA cord faulty.
Nov 09, 2008 | Princeton Digital VL1918 Monitor
Need new power cord for x2gen monitor
You should be able to go to any local store like BestBuy and pick up a power cable. The monitor uses the same power cable as a Desktop PC.
Here is a picture: http://www.cablestogo.com/product.asp?cat%5Fid=914&sku=03129
Mar 14, 2008 | X2Gen MG19MY 19" LCD Monitor
E-Machines eMachines Desktop PC Logo
185 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
