Question about Keyless Entry Remote Fob Clicker for 2004 Malibu Memory 2 (Mus
I have Tahoe 2008. all doors lock and unlock, but the passenger side is not working like the rest. what is the problem. is it programming or something else. please advice
    New Friend:
  • 103 Answers
You need to get a new actuator. Check it with the switch inside to verify the mechanism. Usually this is an indication that the actuator is bad, especially when all the other ones function correctly.
Posted on Aug 21, 2010
Why doesn't passenger door unlock with key fob or switch?
Dannie, power lock actuator faulty. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Front Door Lock Actuator Replacement 2007 to 2012 Tahoe Silverado...
How to remove door panel 2008 Chevrolet Silverado 1500 LT better quality
Automatic Power door lock repair 2007 2014 GM Truck Suburban
Mar 30, 2016 | 2008 Chevrolet Chevrolet Avalanche 1500...
How do I fix the passenger side door lock that does not lock or unlock with the button?
door lock actuator inside the door itself would be the best place to start!
Feb 20, 2015 | 2008 Chevrolet Impala
Can you help me figure out why all the doors on my 2003 Tahoe lock properly but the right passenger which all of the sudden reversed pattern? In other words, when I put it in gear they all lock but th
Yeah. your BCM(body control module) has decided it doesn't want to work right. Since you can double click it and it works, leads to an internal problem with the BCM. Personally, I would live with it. New or rebuilt BCM's are cheap and then you have to have them programmed..$300+
Nov 11, 2014 | 2003 Chevrolet Tahoe
2007 chevy tahoe touch screen radio will not respond to touch, everything else works fine.
If the electrical contacts that go to the rear door lock are corroded the lock/unlock switch will not work. Spray WD-40 (with the spray wand) from inside the truck into the space between the truck and door on the passenger side. A few squirts near the top and upper side will give enough electrical conductivity to energize the lock.
Oct 29, 2013 | 2007 Chevrolet Tahoe
2005 Chevrolet Tahoe Power Windows and Power Locks not working.
The power windows an power locks are controlled by a module , DDM - driver door module . As far as the locks locking when you put the vehicle into reverse an unlocking when you put the vehicle into park , that's how there are suppose to work , automatic lock an unlock feature . When you put the vehicle into any gear from park the locks should lock . Did she hit window lockout function ?
The power door lock system consists of the following components:
• The driver door module (DDM)
• The passenger door module (PDM)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock switch
• The door lock relay
• The door unlock relay
• The liftgate lock relay--utility vehicles with liftgate only
• The reversible door lock actuators in each of the doors and liftgate
• LOCKS 20A fuse (rear lock/unlock relay supply voltage)
• ECC 10A fuse (liftgate lock relay supply voltage .
Programmable Automatic Door Locks
The automatic door lock feature can be programmed to control the door lock system. The automatic door lock feature is factory programmed to have all doors lock and unlock. For detailed instructions on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
When the automatic door lock feature is programmed to control the door lock system, the driver door module (DDM), passenger door module (PDM) and body control module (BCM) will lock the vehicle doors if the following inputs are true:
• Ignition 1 input is active.
• All door jamb switch inputs are inactive.
• Cargo door or liftgate/liftglass ajar inputs are inactive.
• Transmission is shifted out of park.
This automatic door lock function will only occur once per ignition cycle unless, a door jamb switch input changes state to active and back to inactive. Then the DDM, PDM and BCM will lock all doors again.
Once the automatic door lock feature has locked the doors, the BCM will then unlock all the doors when the transmission is shifted into park.
Driver, Passenger and Cargo Door Lock System Operation
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock relays and also send a Class 2 message to the DDM and PDM to perform the appropriate function.
The modules which activate the power lock motors are:
• The DDM (driver door lock actuator).
• The PDM (passenger front door lock actuator).
• The BCM (both rear door lock actuators and cargo door/liftgate).
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and cargo doors differ slightly in that they use lock and unlock relays. The relays supply and coil sides receive a constant voltage through the battery voltage supply circuit. The normally closed contacts are connected to ground and the control side is connected to the BCM. Once a door lock or unlock request has been received by the BCM, the BCM will ground the control side of the appropriate relay. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
Mar 16, 2017 | 2005 Chevrolet Tahoe
Power door lock does not engage lock works manually
Try wiggling the electrical harness between the door and body of the truck with the door open and switch engaged.
Aug 07, 2012 | 1995 Chevrolet Tahoe
2008 Tahoe-Remote won't lock or unlock the Drivers side lock
more than likely the lock solenoid in the driver side door is not working. it located near the latch inside the door.
Aug 24, 2009 | 2004 Honda Civic
Unlock button on passenger door doesn't work. To lock, it does work but no to unlock.
It will only lock all doors, but should only unlock passenger door.
May 30, 2009 | 2008 Jeep Grand Cherokee
2004 tahoe
make sure than you have not split any fluids on the passenger front door most of the times is where the module to control the windows and doors is located, try by unpluging the batterie and the after a minute plug it back and see what happend but if any of your ft doors have been split with liquid or rain has gone inside then most likelly the module got moisture and not working
May 31, 2008 | 2003 GMC Yukon
Keyless Entry Remote Fob Clicker for 2004  Malibu  Memory 2 (Mus Logo
131 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
