Question about Cameras
When I press the on button it flashes on then turns off right away, I have replaced a new battery and its still the same
  • 724 Answers
Use a good higher mAh battery set
Posted on Aug 20, 2010
How do you access trouble codes on 2003 harley davidson deuce?
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
May 20, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
Battery light flashing orange, orange, orange, then green over and over. if I unplug the computer it will turn off right away. I changed the battery to one that I had stored away and it's still doing the...
That usually means that you're battery has exceeded it's life expectancy and needs to be replaced. Could also mean that the circuit on your system board that charges your battery is defective and not charging your battery. Remove the battery and use the AC adapter and see if the the laptop turns on with out the Yellow LED flashing.
If so, then you either need a new battery or new system board. If the latter, might be chwaper to buy new computer.
Aug 23, 2013 | Dell Inspiron E1405 Notebook
I have 3 wii remotes was using one that had batteries it died so i replaced all remotes with new batteries and now none of them will sync or work they just turn off right away
After replacing the batteries, you may have to do a hard sync by pressing the sync button beside the SD slot on the Wii and the sync button on the back of the Wiimote underneath the battery cover. Both buttons are a kind of dark reddish-brown colour.
Mar 25, 2011 | Nintendo Wii Console
How do i change the time on the timex 1440 i change it once before but i through the derections away and now evertime i try too change it again it just goes to stop watch so i think i must be doing...
Hi jazzz78d,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Nov 09, 2010 | Timex 1440 Nylon watch
Flashing orange light, third from the left on the front edge, left side. Just replaced the battery yesterday.....
I had same problem. PC wouldn't even start at all. New cord & battery.Computer repairman said- remove battery, remove electrical power (& unplug the cord from power source :) don't electrocute yourself), then press the start button for at least 30 seconds. I pressed it for about a minute. Replace battery & power, (don't forget to plug the cord into electricity again), and press start button. That resets something inside.
It worked!!!! I couldn't believe it. I almost gave it away before I called repair guy. Yikes. :)
Feb 17, 2010 | Dell Inspiron B130 Notebook
PRG120 button tone
Does the alarm work? if not, it is quite likely the battery is low. You can tape it up in a window to recharge the battery for a couple of days, direct sunlight is not necessary. Normally "Recovering" flashes. If the battery has been depleted for too long, it is possible the battery is now damaged and may need to be replaced.
As for settings, try pressing both buttons on the right side simultaneously in various modes, especially settings or alarm modes and see if that turns back on the beep. Perhaps press the upper left button for 5 seconds until various options start flashing, then try double right button presses and see what happens.
Hope one of these helps.
May 07, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
EX-S880 Shutdown
First off make sure that the battery when charging is a solid red light and NOT flashing. If it's flashing that means we have a problem with the battery.
Make sure you are only using a Toshiba, Panasonic or Sandisc memory card that is no larger than 1 GB unless you did a firmware upgrade to handle a larger card.
Take your memory card out. Turn the camera on and press menu, go over to setup, go down to format (this will format anything on the internal memory of camera) and press right arrow to highlight format and then press ok button. It will say busy please wait and then once that's done please press menu again, go to setup, go down to reset, press right arrow, highlight reset and press ok.
If the camera is still acting up after doing this please contact Casio repairs and they can fix it for an electrical issue.
Apr 27, 2008 | Casio Exilim EX-S880 Digital Camera
Camera Won't Turn On
I have bought many "broken" Casio cameras that had this issue. 9 out of 10 were easily fixed.
The first thing you do is remove the battery and card. Let the camera sit empty overnight. Next morning, take the camera and puch down on the power button...the on and off button. Hold it for 15 seconds. Release it after that 15 seconds. This will reset the camera. Then try the battery and card again. Many times...that is all it takes.
If that doesn't do it...but a new battery (NP 20) they sell on Ebay...no more than $7 as rule with shipping. Buy a new charger as well...no more than $8 usually..same place. Do not throw away your camera or take it in for repairs until you at least try this. It could be the cheapest fix possible.
If a new and charged battery still doesn't work, it may be the connection points...inside the camera...the little springs you see when you look into the battery slot. I have never had to adjust these as they were never the problem. What is sometimes the problem, id when the battery is pushed into place...the right way and not backwards (we have ALL done it!) there is a little latch that comes out from the side to hold the battery in...make sure it does in fact hold the battery in tight before shutting the battery cover. The battery cover does not have to be closed for the battery to work.
If all the above fails...sell me the camera and charger and battery...seriously!!
Dec 05, 2007 | Casio Exilim EX-S600 Digital Camera
Flash wont work
this is probably because you either have it on close up reang (the button on the top/side or your out of battery
Feb 27, 2007 | DXG Technology DXG-506V DV Digital...
Cameras Logo
43 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
