Question about Mitsubishi WS-55613 55" Rear Projection HDTV
I have a Mitsubishi Medallion 62' 1080 Model WS 65611. My power went out, the timer button is blinking and the TV wont turn on.
Light flashes two times, then pauses, then two times. Help!
Posted on Oct 30, 2013
premtech
  • 934 Answers
SOURCE: Mitsubishi WS-65611
Just from what you've described it could be any number of things. One of the more common problems is the convergence Ic8c00 Stk393-110 Mits. Part # 267p155010 and the fuse 9a04... On a scale of 1 to 10 and 10 being the most difficult the task is about an 8 to replace and trace test the convergence circuit. You can however check and see if 9a04 is open, and if so, then you know where the problem is and can be more informed when asking a shop about what they charge to repair this problem. Take a VU or DMM meter set on continuity and loacte 9a04. That location number will be printed on the board right next to the component you're looking for... Next test it for continuity. If you get no reading it's open and the convergence amp is the culprit. Hope this helps. Bill
Posted on Jun 06, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi Medallion HD 1080 model ws-48413
when the led is flashing does it flash a two digit error code? Let me know I should be able to help you with it.
Posted on May 08, 2008
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
SOURCE: mitsubishi WS-55859
Easy to fix this problem, I did 1 mounth ago. 30 min and $20 dollar
Posted on Dec 30, 2008
  • 14 Answers
SOURCE: my t.v. wont turn on.
hold down the menu + device for five sec what is the error code?
should be like 1 pause then a 2 or something
Posted on Feb 10, 2009
I have a Mitsubishi Medallion Model # WS-65611 rear projection TV that has stopped working and is consistently blinking with no specific code. It is about 8 years old. It will not react to the on / off...
There is no cost here. We give free advice. It sounds like the power board is not giving any power to the rest of the boards on the television.
Oct 28, 2013 | Televison & Video
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
I hope that helps.
on May 04, 2010 | Televison & Video
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Ws-65611 wont power on
Most likely bad caps on the dm board.
Sep 05, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My tv turns on the shuts off on its own
This unit will not indicate any problem without you doing something to initiate the LED diagnostic feature. Go to the front of the set and hit the power button, when that doesn't work hold the MENU and INPUT buttons on the set at the same time for 10 seconds. The power LED should start blinking a two sequence code that will repeat six times. The number of blinks will tell the general area of the problem. As an example a 2 - 2 sequence is a convergence output problem over 95% of the time.
Jun 04, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Cant connect VGA form laptop to TV.
Sounds like you may be trying to use a resolution or scan rate the TV does not support. Many of these televisions do not support 720p, but DO support 1080i.
Good luck.
Mar 02, 2009 | Mitsubishi WS-65611 65" Rear Projection...
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
556 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
