Question about Proform ZT5 Treadmill
Display on proform zt5 treadmill will not go off
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
maxtreadmill
  • 832 Answers
SOURCE: Proform treadmill console displays FF and will not
SOUND LIKE YOU HAVE A UPPER DISPLAY PROBLEM SINCE I DO NOT KNOW THE MODEL# IT SAFE TO SAY THAT THOSE CONSOLE CAN BE RATHER EXPENSIVE.
GO TO iconfitness.com to customer service then replacement part and put the model# in and it will tell status of parts and pricing or call them @1-800-999-3756
Posted on Mar 01, 2010
  • 82 Answers
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
Posted on Apr 22, 2010
maxtreadmill
  • 832 Answers
SOURCE: proform treadmill zt 5 runs but display is dead
If what you say is that all functions are working (start, speed up , down and incline up,down) then the upper console lighting may have loose wire harness( check first) bad soldier connection or the components that generate the images on the LCD are defective. If you have good connections on the wire harness then you may need to replace the upper console.
Posted on May 22, 2010
Proform ZT5 Treadmill, PFTL60509. The display works but the light has burned out. I'm not sure if it has a bulb? Can I fix the light without having to replace the console?
No don't light only seven segment display, you must replace the complete display board. go to www. fitnessrepairparts.com and get it
of course try if the ribbon cable is loose, or dirty, and clean with contact cleaner and try again. However you must try to adjust the REED swtich, and adjust it.
Oct 02, 2013 | Proform Exercise & Fitness
It beeps but none of the controls work
1) replace old batteries with alkaline
2) clean the contacts baterries very well
3)tight the ribbon cable for keypads inside from display board and clean it the ribbon cable.
4)Adjut the REED swithc, clean it, test for open or faulty, and tight the connector. see the diagram attached.
Jan 14, 2013 | Proform ZT5 Treadmill
Controls are on but treadmill does not come on
LUBE ACCORDING with the Video. God bless you
Jan 07, 2013 | Proform ZT5 Treadmill
Display Doesnt turn on
1) change the batteries by news one
2) clean the contacts batteries very well
3) tight the ribbon cables from keypads from display board.
4) tight the wires connector from display board vs lower board
5) Adjust the reed switch see the diagram, clean it and tight the wire connector well.
6) After you fix it RUN the software calibration for diagnose , troubleshooting and fix it.
God bless you
Jul 12, 2012 | Proform ZT5 Treadmill
Battery compartment for a Pro Form ZT5
see the intruction manual, for to proceed with the change batteries compartment. You can clean the contacts batteries with special spray from Radio Shack. IF you need replace the comparments go :
www. fitnessrepairparts.com and buy it.
if you need download for free the instruction manual go : www.fitness.manualsonline. com or www. iconservice.com
sincerely. God bless you
Apr 28, 2012 | Proform ZT5 Treadmill
Proform ZT5 Treadmill clicking noise
Dear Sir:
If it sounds like metal rotating on metal then it could be roller bearings or motor bearings. Most of the time the bearings will have to be pressed out and the new ones pressed in. May be you must go the treadmill to workshop. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 05, 2012 | Proform ZT5 Treadmill
Treadmill keeps inclining and declining . It won't stop!
I have a Proform ZT5 model - had the same incline/decline problem. It needed calibrated.
- unplug, turn off, and take the key out
- plug machine in
- turn switch on
- Pres and hold the STOP and SPEED UP button at the same time, while holding them insert the RED KEY
- let go of both buttons
- press STOP 1 time
- pres INCLINE UP 1 time
- this should reset it.
The tech on the phone mentioned the importance of turning the maching off, taking the key out, and unplugging after each use. Leaving it plugged in there is still an electrical current running and this can cause more seriouc problems that require a new control panel.
May 08, 2011 | Proform ZT5 Treadmill
Proform treadmill zt 5 runs but display is dead
May 21, 2010 | Proform ZT5 Treadmill
Proform ZT5 Treadmill Logo
73 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
