Question about Kenmore Washing Machines
Kenmore elite he3. Soap not being dispensed. Water is coming into dispensing area, just water holes toward back. No water out of front holes
  • Kenmore Master
  • 12,061 Answers
If your dishwasher soap dispenser is not opening, verify the following:
When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the lever is defective, the cup will not open; check the link and repair or replace it, as necessary.
Some older models have dispensers have a bi-metal switch that deforms away from the detergent cup latch, opening the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup and you will need to replace it. Newer models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door.
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup will take care of the problem.
Click here to see your dispenser cup. It has a switch on the back that is probably defective and you will need to replace the entire cup.
I would try cleaning it out first and if it still doesn't work replace the dispenser. The detergent dispenser and the rinse aid dispenser are included in the same part.
To remove the rinse dispenser start by turning the power off to the dishwasher.
  • Open the door and remove the screws on either side of the door. Don't remove the screws at the top area that hold the control panel on. Hold the panel with one hand while you remove the last screw as it will fall.
  • Remove the screws holding the rinse dispenser to the door and disconnect the wires from the dispenser.Note the position of the wires for reinstallation.
You can now take the dispenser to the sink and wash the rinse dispenser out. Don't immerse the dispenser in water, run water inside the rinse dispenser and shake it to clean it. If this doesn't fix the problem use this same procedure to replace the dispenser.
Posted on Aug 20, 2010
Water leaks out of the soap dispenser of my kenmore elite front loader and all the soap or bleach us not out
The 1st thing to try is to take out the dispenser ,there is a little piece that you will push down and then pull the entire assembly out, rinse it out with hot water ,most likely there is a build up in the dispenser,there after use only powder detergent, and no more then 1 tbs ,and any other stuff IE bleach ,fabric softener,use 1/2 the amount and dilute it with water.
Jul 20, 2014 | Kenmore Elite 45986 Front Load Washer
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
I have a kenmore elite HE3 t and latley after it's
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3t Front Load Washer leak from dispenser
I was just about to call the service teck when I decided I shouldn't be this stupid and try and fix it myself.
I took the tray out and looked in with a flashlight.
Saw nothing.
Cleaned the tray and then checked the drainage hole inside the opening where the tray normally feeds the machine the soap.
I found a inside of the liquid XXXKing laundry cap partially blocking the drain.
Took it out and works fine.
Sep 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Soap Dispenser won't empty
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 Washer fabric dispenser not working
This is usually just as simple as adjusting the syphone up and down. releveling your machine or cleaning the dispenser itself. when the water enters the dispenser gravity syphones the water out . nothing really machanical about it. unless the water is not filling up the cup enough to go above the max line. you can test it by putting water in the dispenser above the max line and adjusting the syphone cap up and down.this should grab a suction.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Water Leaking really bad from the Dispenser area
Disconnect the plug from the outlet. Remove the top of the washer panel by removing the 2 back hex screws then sliding it back to lift it off of the washer. Take off the front control panel by removing the phillips screws holding it in place. Remove the dispenser drawer. Check the dispenser housing for clogs or lime build up at the bottom of the dispenser housing. Or the drain hose (large black hose attached to the front of the drawer housing) to the washer may be crimped or clogged.
Aug 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore he3
Getting around the way the boards are pre-programmed is not something they write into the manuals or even make programable. If you want to soak with more bleach, open the dispenser drawer after the unit has filled and add a bleach/ water miture to the soap area of the dispenser. This will let it run into the machine and will get you more bleach in there.
Apr 05, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
74 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
