Question about Toro Lawn Mower With Toro Power Tools
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
Posted on Aug 28, 2010
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Starts and runs great(when engine is cold).\r\nafter 15 mins the engine dies. will start up again, but will only run about 5 sec. and then dies. toro super recycler 5.5 hp GTS5
I would check the gas cap. If the gas cap is plugged or pieces missing from inside it will not allow air into the tank and the fuel will not flow properly to the carburetor. Just loosen the cap and try it, if it does not change check for dirt in the fuel line.
Jun 15, 2011 | Toro Garden
TORO 6.5 RUNS FOR 4 SECONDS AFTER PRIMING THEN DIES.pUT IN NEW SPARK PLUG,new gas,but after priming run for several seconds.. it dies again....can you help...sounds like dirt in carb??/ It had run...
Did you check the filter? If the engine doesn't get air they it could cause it to die out like that. Also make sure that there isn't anything in the air line to the carb.
Did you check the gas line and make sure that you are getting enough fuel?
Jun 05, 2011 | Toro Lawn Mower With Toro Power Tools
Have a Toro GPS5 600 lawnmower. Starts with Choke on, but dies if you move off choke. Also, runs fast and slow when blade engaged. I heard carb for this unit are no longer available. Help
May 16, 2010 | Toro Lawn Mower With Toro Power Tools
Mower starts and stops with in a few seconds
Ok your not getting fuel into the carburetor it sounds. This could be either your carb.needs cleaned or your low idle screw on the carb. needs adjusted. The idle screw is located directly underneath the air filter. Remove filter and turn clockwise all the way and then counter-clockwise 2 1/4 turns, then test. Adjust until it sounds about right.
Sep 22, 2009 | Toro Lawn Mower With Toro Power Tools
I have to prime the toro mower every time I empty the bag to get it to start?
  1. what is the model, manufacturer and year of mower?
  2. has any maintenance been performed on this mower?
  3. if no, try replacing the spark plug and air filter (it's possible the spark plug could be fouled and/or the air filter is clogged) be sure to follow the manufacturers recommendations for oil, gas, filters and plugs.
routine maintenance involves:
  1. sharpen/replace blade
  2. oil change
  3. replace air filter
  4. replace spark plug
  5. new gas
Aug 31, 2009 | Toro Lawn Mower With Toro Power Tools
Trouble starting the mower
check the oil level , oil change?, spark plug check/clean. air filter check. is the deck clogged with grass? then let me know how it starts
Mar 20, 2009 | Toro Lawn Mower With Toro Power Tools
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Sep 28, 2008 | Toro Garden
Toro Lawn Mower With Toro Power Tools Logo
547 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
