Question about Uniden Cordless Phone
Dead Uniden DCT5280 Handset
One of my three Uniden DCT5280 cordless phone Handsets has died. Uniden has discontinued the phone. Is it possible to get another model handset that will work with the Uniden DCT5280 base unit?
  • qaweenie May 21, 2008
    Thanks a bunch!
    Genius:
  • 1,224 Answers
If battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
Posted on May 10, 2008
Base handset not working
try taking batterie out reset it 2 min then back in and unplug base might wann buy new battery also for that one
Jan 30, 2008 | Uniden Cordless Phone
I have a uniden 5.8GHz cordless phone with 3 handsets. But now 2 of the handsets do not work. The base lights up to show it is charging and when I pick up the phone, the handset says...
You may have a problem with your battery. Usually the rechargeable battery goes bad on those units. Swap the battery from the working handset to one of the non working ones.
Dec 16, 2017 | Uniden 5.8GHz Cordless Phone
Uniden 5.8 cordless phone - replaced batteries, but now the phones don't ring....help?
up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Uniden Cordless Phone
Phone disconection
cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU butTton on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced CERTIFIED UNIDEN EXPERT
Jan 21, 2011 | Uniden Cordless Phone
Uniden handet does not work
If you have had phone for about a year, yes.
Mar 14, 2009 | Uniden DECT 6.0 Cordless Telephone...
Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Oct 06, 2008 | Uniden Cordless Phone
Deregister lost or broken phones
Some tricks from a helpful Uniden rep:
holding down end+# keys at the same time on the phone for about 10 secs (you will hear a beep) will deregister the handset. If you have a dead handset and want to deregister it from the base, you have to reset the base. unplug the phoneline and power. hold down the "delete message" key, plug power back in. about 10 secs later, you will hear a long beep (theres a short beep upon powerup as well). At this point all handsets are deregistred and you will have to reregister them with the end+# trick. this way when #1 handset is dead, you can make a working one #1 and get the broken one fixed emotion-1.gif
BTW, this is a woot warranty, not uniden warranty. however the uniden rep gave me the number to the people who refurb (rox0rz!) these. I'll post an update when I finally get ahold of them (and the number if its actually helpful)
Jun 20, 2008 | Uniden TRU8885 Cordless Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Uniden Cordless Phone Logo
260 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
