Question about Plantronics 510 Voyager Headset - PLN-510 Headset
How do you program it to phone? - Plantronics 510 Voyager Headset - PLN-510 Headset
  • 3,153 Answers
Basicly tunr on your phone and go to the bluetooth options and set it to pairing (options vary a little phone to phone) and once it is set to look for or accept incomming connections then turn on the heaset
At this point it may well ask for a security code.
That would be listed in the headset manual but two common ones are also 0000 or 1234
At which time you should see activity on your phone and the two items should hook up together
Without the phone model it is a little hard to be very specific but you should be able to get by with the instructions above
Posted on Aug 20, 2010
  • The answers by Project Nomad / bob_computer are to be considered copyright 2011 and property of
    R. Humpleby
    Use without prior "written permission" is no longer allowed.
    This property is no longer shared with Fixya and its associates / affiliates
    It's removal from puplic view is requested
    Reason. account termination.
How do i keep my phone from freezing up as soon as it starts up
you have to many apps running and programs
you need to remove a lot of them
here is whats going on lets say you phone is a empty jar, and the apps are sand, i take a funnel start pouring sand into the jar, at some point the jar is going to fill up. my phone has lots of appts., scanner, music, games, anti virus programs, management software, youtube,
phone numbers, data information, bank stuff, password programs, and so on.
when you turn the phone off at night to charge the phone, than in the morning you turn on the phone, your phone has to load all the appts,
programs, games, bank info., anti -virus and any other program you installed.
you have limited amount of memory and the phone is trying to load all the program and turn on the phone and run other options.
_____________________important to try______________________
go into phone store look for a program called the following
CLEAN MASTER it should be free
it will help with junk files, privacy, memory boost, app manager
_______________________________________________________
also in the program there is a advanced section that will allow you to move some program from the phone to you micro SD card if you have one.
i hope this this will help resolve a lot of issues, keep the phone a little cooler, when you put thing on the sd card they are stored on the card not the phone when the phone turns on everything on the sd chip is loaded into the memory of the phone there should not be loss of time or long waits for the appts to activate or run
Apr 16, 2015 | Samsung Centura - Straight Talk Wireless
EXECUTONE 64800 PHONE, HOW TO PROGRAM STATION SPEED DIAL # 'S
from the phone press program key, than 01 for speed dial 1 and then the phone number you need to program in under speed dial 1, after done, press program key. to dial out press outside line key, than program 01 and it will dial out to that numeber. you have 30 speed dials per phone.
Jan 09, 2014 | Executone 64 Corded Phone
I buy a lg model v10000s voyager but when i turn on the first message is initial programming needed, i have my account whit verizon but my phone is old. i just wanna changed, but i can't because i need...
This means that the phone has not been programmed. Call Verizon customer service to activate the phone.You can also program the phone by calling *228 and choosing option to program the phone.
Feb 26, 2011 | Cell Phones
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
How do I program alucent Pasartner 18 phone-- new line has been added by verizon but we need to program phone to accept the new line
you will have to go into system programming.
#301 will add it to each extension.
If you have no special ringing programs on all extensions (all phones ring immediately) you can do the initial line programming, #104, but that will reset all lines.
Oct 14, 2009 | AT&T Partner 18 Phone (315805B)
I DON'T know what is initial programming is?
initial programming occurs when your phone needs a second roaming based and if you accidentally change the NAM settings of your phone to NAM2. the default NAM settings of your phone is NAM1.
Jul 01, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Programming resets on Biz10
This is a very old system. Phones loose programming if power is lost.
There was no way of backing up programming on phones at those times.
And unfortunately you do have to go to each phone to program ringing scheme.
Jun 18, 2009 | AT&T Merlin BIS 10 Phone
Phones all lit up
Hello, the lights ( buttons ) can be programmed on each phone according to the users need. To program a button press PROGRAM and then the button you want to assign. Now press 1 followed by the extension number you want to assign to the button. Press AUTO DIAL / STORE to save your changes. Press PROGRAM to exit program mode.
NB - Be sure not to program all buttons as extensions. Leave some buttons for CO lines, otherwise you won't be able to phone out.
Thank you
May 22, 2009 | Panasonic KX-T7633B Corded Phone
Initial programming needed.
Call your service provider to have it reprogrammed.
This means maybe someone deleted the basic programing features of your phone like phone number. or the system ID got bumped by a software error. or it could be that the phone just got flashed. i know the code to program the phone but if you don't know about internal programing it will do more damage than good. since it will kill your phone if any wrong settings is applied.
Best bet is to have your service provider tell you the programing code and settings to be changed. because they will be telling you over the phone what to do.
Feb 23, 2008 | Motorola Mobility W315 Cellular Phone
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
370 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
