Darken screen - Computers & Internet
    Genius:
  • 2,785 Answers
Have you check the brightness and contrast settings if yes then your monitor needs servicing
Posted on May 03, 2008
I will like my computer screen darken
check the setting from there you can or from your keyboard you can also
Jan 02, 2014 | AOC LM742 17" LCD Monitor
How to increase the brightness on a TI-30X
there is no actual way to UN dim or darken your screen its a calculator not a phone try cleaning the screen or resting it
other then that give up and stop looking for solutions cause it is a wiast of your time for one calculator
Feb 11, 2013 | Texas Instruments TI 30XIIS Scientific...
Gateway laptop screen darkens after boot up
Have you updated a Graphic driver? Does it Dim on battery and AC? Look at power settings. Control Panel, Power. You could Rool-Back the graphic driver to see if that changes the problem. A Gateway mt6841 has Windows XP OS, right?
Nov 27, 2012 | Gateway MT6841 15.4 WXGA SHINY LCD SCREEN
Tv screen darkens at night
The set likely has a light sensor on the front of it to change brightness with light changes in the room, if not in the menu to switch on or off contact LG to see with the model number what can be done.
I have seen some where the sensor had to be disconnected inside to correct this issue. Sets as far back as 50 years ago had this issue.
Oct 22, 2012 | LG Televison & Video
LOOKING FOR A REPLACEMENT SCREEN
Darken the screen and either move the lid forward or backwards. Laptops have Liquid Crystal Screens and moving the lid backwards or forward will give the screen a different look.
If you need to adjust the brightness of the screen it is controlled by keys on your laptop. Most times to darken the screen you will have to hit the FN, CTRL or ALT key and hold it down while you hit the key that corresponds to the screen darken key. On some computers (even on my laptop) it will be the down arrow key, so i would press FN+the down arrow key. Remember to hold the first key down while you hit the next key. The icon used for most times to denote the brightness or darkness looks like a circular sun or a washer that goes on screws.
Mar 22, 2012 | Computers & Internet
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
My kid's calculator is not working; replaced new batteries including the lithium battery. yet, the calculator is not turning on.
After a battery replacement the screen contrast may become too dark or too light. I suspect that in your case the screen is too light. To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] until screen darkens enough.
Jan 30, 2010 | Texas Instruments TI-84 Plus Silver...
My TI 84's screen went black.
One possible solution is to dim the screen contrast. To do this, turn the calculator on press the 2nd key, then the up arrow. If contrast has been darkened, this should work. To darken the screen if you get it too light, you do the same, but use the down arrow. Hope this helps.
Oct 01, 2009 | Texas Instruments TI-84 Plus Silver...
Question about my battery and screen darkening on my sony vaio laptop
i need to know what do u want to know about the battery and as far as the screen darkening go into bios and go to power options and ensure that it is set to max performance the screen will be bright if it is set to user settings it will be darker
Aug 21, 2008 | Sony Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
