Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a husqvarna YTH150 hydrostatic kohler motor 1995-1999 upon starting it takes many tries then when started its like its on a steady idle it'll idle high then low in a steady rotation until it cuts off or i put it in gear and then it shuts off it worked perfectly fine until i mowed the grass one evening and it jus shut off going up a hill and i tried a spark plug any suggestions i'd really appreciate it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Sounds like fuel starvation, clean the fuel filter and lines, make sure there's no muck in the fuel tank. It's also possible the choke is sticking, although the exhaust would smoke and smell of petrol (gasoline).
Posted on Sep 10, 2010
I have aN ARIENS 42" a husqvarna mate. I found a wire off and not sure where it goes, it will not start
that might not have anything to do with your issue. there are plugs that aren't used...
does it crank and not start
or
not crank ???
Oct 20, 2014 | Ariens Riding Lawn Mower. 42 in. 19 HP...
Kohler engine troubleshooting
Do you hear the fuel pump running? Is there gas coming out of the pump? Could be a bad wire connection to the fuel pump or bad ground connection.
Aug 03, 2014 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
Husqvarna hydrostatic transmission
my transmission on the right side do not have the power the lifr side have what do i need to do to fix it
May 14, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Not starting
sounds like the starter drive is worn out or the drive gear is not engaging the flywheel need to remove the starter and check drive gear
Oct 04, 2012 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
I have a husqvarna lgt2554 mower ... wont start, whines. Makes the whiney sound when I try to start it with the key or when I try to jump it by the solenoid. Does this mean its a bad starter??
It could well be the starter motor, but you need to check the gear on the end of the motor, it maybe the teeth half worn, this part will be a lot cheaper than changing the complete motor.
Mar 11, 2012 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How do I check fluid level on YTH150 Hydrostatic Transaxle?
My Husqvarna hyrdrostatic transmission is sealed, and yours may very well be also. That means no changing the fluid.
May 13, 2009 | Husqvarna Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
533 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
