Question about Dymo LetraTAG Thermal Label Printer
The labeller says "Error1" when I press print. I have changed batteries. Not sure what the problem is?
    President:
  • 405 Answers
Error 1 indicates a tape jam or low battery. To resolve, try removing the cassette and clearing the tape or replacing the battery.
Posted on Aug 20, 2010
I'm trying to print and keep getting Error1.New batteries and new tape cartridge.
You can try to reset the device to its factory settings by taking out the batteries and pressing the ON/OFF button 20 times. Then insert the batteries and try again. If this doesn't fix the issue, please contact us so we can find a solution for you.
http://global.dymo.com/Default.aspx?locale=n
Best regards,
ST
DYMO Support
Jan 15, 2015 | Dymo LetraTag QX50 Thermal Label Printer
Nothing happens escept error1 when print button is pushed
Tape jam or battery low. Please clean the printer and/or exchange the batteries.
Aug 20, 2011 | Dymo LetraTag QX50 Thermal Label Printer
HAVE A FLASHING ERROR LIGHT. CHECK RIBBON. RIBBON IS NOT USED ON THIS PRINTER. HOW DO I CLEAR THIS UP?
Changing the setting on the printer The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
Jul 09, 2011 | Zebra 105SL Thermal Label Printer
I've got some problems with my zebra zm400 printer. It says error ribbin out
May 05, 2011 | Zebra 203DPI Printer
JAM LABEL
1. Turn the printer on and make sure that the LCD display reads 'ON LINE'.
2. Press the PAUSE key once. [The display will read 'PAUSE'.]
3. Press and hold the PAUSE key until four or five labels feed forward.
NOTE: On some models, pressing the pause key will change the LCD display to 'TRANSMISSIVE'. If this happens, repeat step 3.
4. Press the RESTART key. The printer will go back ON LINE.
5. Open the print head and reposition your labels, so that they are ready for printing. Close the print head.
Nov 17, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
Error 1
I had this, a small piece of label had got stuck behind the wheel, couldn't see it at first but with a bright light and a fine tweezers got it out. Check the drive wheel is turning if not you've probably got it jammed somehow. Also change the batteries, leave out a while and then replace. Also make sure the tiny lever on the top right is down (wont drive the tape unless down or the lid fixed back on)
Oct 04, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Dymo Letra Tag
I have to assume you are pressing the print button. That being the case, either your batteries are weak or the tape is empty or jammed.
Aug 28, 2008 | Dymo LetraTAG Thermal Label Printer
I have a casio kl-60 EZ-LABEL Printer my batt was low tried to print and labeler said ERR. Changed Batteries still said ERR. Please help lost manual. Tried to find manual online. would be nice to have.
to reset memory
1. Make sure that label printer is off
2. While holding down the PRINT and ESC keys, press ON?OFF to power on.
3. KEEPING PRINT and ESC held down, release the ON?OFF key only.
4. Release PRINT and ESC keys.
5. Press SET to initialize the Label Printer or ESC to Abort
http://ftp.casio.co.jp/pub/world_manual/ds/en/KL_60_E.pdf
Aug 14, 2008 | Casio Computers & Internet
Brother PT-85
Make sure you have fresh batteries, It sounds like the batteries are low,
Lou
Aug 10, 2008 | Brother P-Touch 1180 Label Printer
Dymo LetraTAG Thermal Label Printer Logo
202 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
