Question about LG Washing Machines
I had order a new washing machine from LG. It's WD11020D, a front loader. However, when taking all the 4 bolts out from the washer. I notice 2 of them were bended. I am worried that it will be difficult to apply the bolts if next time I want to transport the washer. One of the customer service suggested that to put weight into the drum during transportation, ie phone books. But this is not the case. AS the manual instructed that all the 4 transit bolts need to be lock when transporting. Will this damage the drum?
Http://manuals.appliancesonline.com.au/lg-frontload-washers/lg_frontload_washers_user_guide.pdf
Posted on Dec 29, 2010
Lg front loader wd11020d water leaking from back of machine. Hoses not leaking filter clear.
MAY BE WATER SEAL HAS GONE,,ITS SOULD BE REPLACE WITH 02 BEARINGS,,,
Dec 15, 2013 | LG Washing Machines
I have an LG front load washer (model# wm1814cw). The machine stops mid cycle but gives no error code. I have to almost unload the washer entirely and then restart the cylce. If I try to begin the
Replaced the sensor and it rocks again. I was about to buy a new washer.
1. Remove the back panel
2. Remove the center bolt that hold the cap which covers the motor coil.
3. Pull the cover out.
4. Remove all the bolts that hold the motor coil. Be carefull not to drop the coil when you take the last bolt out.
5. Remove the old sensor and replace the new one.
6. Put back every thing and it will rock again.
Jul 22, 2012 | LG WM1814CW Front Load Washer
We can not find instructions in our owners manual as to where the bleach is to be filled in our front load LG WD11020D washer? Can you tell us where to fill it and how much to use? Thanks
Hi!!
You can use washing detergent w/bleach on the main wash detergent dispenser, this has to be approved for front washer use and should have a label stating so. About the amount to be used, follow the indications on the package.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 03, 2011 | LG Washing Machines
I need a manual for my LG WD11020D front load washing machine
go here http://ebookpin.com/electronics/lg-washing-machine-owner-manual-wd13020d-wd12020d-wd11020d-pdf but after opening it do NOT try to scroll - it will crash. Instead go to menu and SAVE AS and then reopen from your local drive
Nov 02, 2010 | Kitchen Ranges
Lg inverter frontloader washing machine wont turn on. screen say's CL??
CL is about the Child Lock which is done by pressing both the buttons together. To release the same do press both the buttons under the display simultaniously
Sep 06, 2009 | LG Washing Machines
LG washerwon't spin
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 03, 2009 | LG WM-2277HW Front Load Washer
Where can I find shipping bolts for our WM0642H washer
All LG front loaders using 2 bolts part #4011FR3159D and 2 bolts part #4011FR3159E. You can order online from LG.
Jun 05, 2009 | LG WM-2077C Front Load Washer
LE code on LG front loader
Switch off machine, unplug, turn the heat setting on the water down. Plug it back in and select your wash setting. Good luck.
Apr 16, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
276 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
