Question about Car Audio & Video
My cigreter lighter is not working please tell me where is fuse box locate
    Brigadier General:
  • 5,158 Answers
Generally the same fuse as the radio. not knowing what type of car you have it's hard to say but locate the fuse box likely under the dash and check that fuse. as a side note if the cigarette lighter doesn't work... plug something else in to make sure it's the fuse.
Posted on Aug 20, 2010
2013 VW Jetta LS, fuse for cigarette lighter is not working. can someone please tell me the location of this 20amp fuse?
fuse location number 42 (20amp)
in the fuse box on the right hand side of the dashboard
Aug 11, 2016 | 2013 Volkswagen Jetta
Tip
Question about fuse
i have a 2003 ford zx2.the cigarrette lighter does work.i looked at the duse box to see where it is located and its not there.everything is listed except for the cigarette lighter which is why i cant loctae where that fuse is.
can you tell me how to locate the ciggarette lighter fuse since it isnt locate on the panel box like the rest of the items.i checked my owners manual and it talks about the ciggarette lighter and the fuse number which is 20A but it doesnt show where it is located.
on May 29, 2008 | 2003 Ford ZX2
Which fuse do I replace for the cigarette lighter
Your owners manual will tell you which fuse and its location on the fuse box panel, which is located behind the pull down tray, to the left of your steering column.
Oct 09, 2015 | 2000 Toyota Camry Solara
Where is the lighter fuse located
Check you drivers manual it will show where the fuse is located and give the correct fuse to replace.
Feb 26, 2015 | 2008 Scion Xb
In my car cigrete lighter and readio are not working
hi. could be the fuse. cigarette lighter and radio are usually on the same fuse in the toyota range. good luck
Mar 05, 2014 | Toyota Yaris Cars & Trucks
Can someone tell me where i can locate cigarette lighter fuse in a toyota funcargo ncp20, i located 2 fuse boxes, 1 under the steering wheel, and other under the hood but on covers don't show a sign of...
put your low lights on,see if sigaret lighter lids up.
box under steeringwheel.take out one by one and see whit fuse,
light goes off.is also possible in the cover off the box is indicated whits one it is
Jul 07, 2013 | Cars & Trucks
I have a 2005 scion xb and my radio stopped working and my cigarette lighter. what could fix this?
The fuse that runs both is blown. Your manual will tell you the location and type needed to fix it. it will probably be a 10 or 15 amp fuse. Most cars have to fuse boxes. One inside and one under the hood. Most likely it will be in the one inside the car. Also, theres usually spare fuses in one of the boxes, so you shouldn't have to buy one. Check and make sure nothing fell into the cigarette lighter socket, like a coin for example. I've seen that countless times. When you find the fuse, pull it out with the white fuse remover located in the fuse box and put the new one in. Hope this helped! Please rate if it did!
Apr 25, 2011 | 2005 Scion xB
Cant find fuse for cigarette lighter in 2008 honda crv
look under ur dashs fuse box covers for a white label which should tell u of the locateion of the fr-acc fuse or rr-acc socket fuse location. replace the burnt fuse or fuses.(acc = accessory)
Apr 01, 2009 | 2009 Honda CR-V
Cigarette lighter not working, no power to it, can you tell me where the fuse is located for it
The fuse for the cigarette lighter is located in the fuse box on the driver side of the car under the dash. It is a blue 15 amp fuse.
When you open this fuse box, you will see some larger relays with 4 rows of fuses below it. The fuse you are looking for is the first fuse in the 2nd row. in the 2002 X-type, that fuse is a little taller than the other ones.
Thanks for using the fixya forums!
Jul 07, 2008 | 2002 Jaguar X-Type
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
