Question about D-Link DI-634M Wireless Router (DI634M)
I had to reset my wireless router (DI - 634M) and now I'm unable to secure the wireless router (current open access). How do I resecure the line?
  • eyotrojans Aug 20, 2010
    Hey,
    My problem begins with your step one. The login URL http://192.168.0.1/login.html gives me the IE error message, IE cannot display the webpage. Is the issue a configuation problem with my router?
    ERIC
  • 4,472 Answers
Refer to p.14 of the manual.
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-634m/di-634m_manual_100.pdf
There it has the illustration. You will want to choose to enable the WEP encryption. Then you make a key in the key section. use numbers and letter to make your own key. Then when you try and connect to the wireless network that is the key you will need to put in to gain access to the network and your network will be secure. If you have any questions or need further assistance please let me know.
Thank you,
Lee
Posted on Aug 20, 2010
    President:
  • 357 Answers
When you log in to the router, in the first tab (You should already be here by default after login), click on "Wireless" and use the following settings for greatest security:
1) SSID - Set an SSID, this can be any phrase that you like.
2) SSID Broadcast - Here you can use either of the settings. If you enable, any device will be able to detect the unit and then they just need to type your WEP key to gain access. If you disable, nobody, including yourself will be able to find the network as the SSID is hidden, instead your network will come up as "Other Network", you will then need to enter the SSID and WEP key to gain access.
3) Security mode - WEP
4) Authentication - Shared Key
5) WEP Encryption - Choose 64 bit
6) WEP Key 1 - Set a phrase that you will easily remember as you will need to use this on all the devices that connect to your network.
7) WPA Mode - WPA2
8) Cipher Type - TKIP
9) Passphrase - Type a passphrase and then confirm it
That's it!
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
I have a dlink model no di-634m where i am unable to connect into net and wireless is not working .... can i get help urs to repair my dlink
Try RESETTING the D-Link back to the default settings.
Press and hold the RESET button at the back of the routerwith the power ON until the LEDs flash at the time the release the RESETbutton.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 22, 2011 | D-Link DI-634M Wireless Router (DI634M)
How do u access ur wireless setup instructions for d-link routers on internet explorer?
Heres a link to the support site http://www.dlink.co.uk/cs/Satellite?c=TechSupport_C&childpagename=DLinkEurope-GB/DLTechProduct&cid=1197319378173&p=1197318962293&packedargs=locale%3D1195806691854&pagename=DLinkEurope-GB/DLWrapper
Quick setup from here ftp://ftp.dlink.co.uk/di_broadband_gateways/di-634m/di-634m_qig_100.pdf user manual from here ftp://ftp.dlink.co.uk/di_broadband_gateways/di-634m/di-634m_manual_100.pdf
Connect the PC to the router by cable then to log into the router using the default settings
  • Open the Web browser.
  • Type in the IP Address of the Router http://192.168.0.1).
  • Type admin in the User Name field.
  • Leave the Password blank.
  • Click OK.
now goto the wireless settings on the router to see the settings being used
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 01, 2010 | D-Link DI-634M Wireless Router (DI634M)
I lost my D Link DI 634M passphrase and security key. How can I recover or reset it?
Link up with LAN
On your internet, type in,
192.168.1.1
now type in the security key.
it should be 1234.
Dec 31, 2009 | D-Link DI-634M Wireless Router (DI634M)
My DI-634m Is not giving me an IP address
Are you trying to connect to the wireless network ?
If you are not getting the IP address then you might not be connected to the wireless network.
Make sure that you know all the correct wireless settings of the router.
If your network is secured then you have the correct network key.
If you are not sure about the wireless settings of the router then you will need to access the router set up.
Click Here for step by step solutions
Nov 13, 2009 | D-Link DI-634M Wireless Router (DI634M)
Can I use a D-Link DI 634M as an access point?
Sure you can! As you can with any wireless router pretty much.
1. Assign the new router (AP) to an IP on your subnet that's not your existing router's IP... i.e. 192.168.0.2
2. Disable the DHCP server on the "AP"
3. Create a new wireless network on the "AP"
4. Plug your existing network/router into a LAN port
DO NOT USE THE WAN PORT
Voila! You have an access point!
Jun 21, 2009 | D-Link DI-634M Wireless Router (DI634M)
How to reset the d-link di-634m wireless router
go to this link to to reset your d-link 634m manually: http://www.retrevo.com/pdf/426bh043/6/Hardware+Overview#q=D-link+DI-634M
Apr 14, 2009 | D-Link DI-634M Wireless Router (DI634M)
I need to access D-Link router from outside the network, how do i do this
http://support.dlink.com/faq/view.asp?prod_id=2229&question=DI-634M
- Take a visit.
Mar 10, 2009 | D-Link DI-634M Wireless Router (DI634M)
DLINK DI-634M WIRELESS ROUTER USED AS A REPEATER?
No. Here is the help guide:
http://support.dlink.com/Emulators/di634m/help_men.html
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 19, 2008 | D-Link DI-634M Wireless Router (DI634M)
Wireless internet
Hi 4ladyj,
plug your laptop into the router with an ethernet cord, and see if you can connect that way. If you can, go into modem settings via IP (or through the software) and change your wireless settings to default..
If that doesn't work, there is a reset button on the back of the unit, press it in with a paper clip and hold it in for 10 seconds, this will reset the router to the factory default settings.
You will have to change all your settings for your connection again.
Mar 28, 2008 | D-Link DI-634M Wireless Router (DI634M)
Wireless network has disappeared !
If I understand your post/description:
1. You have both wired and wireless clients tied to the DLink DI-634M router;
2. The 1st PC is a desktop that uses Ethernet connections to the DLink and is currently working;
3. You have another (2nd) PC (a laptop?) that is connect by WiFi to the router. This is not working now;
I think that your issue may have to do with the Wireless networking of your 2nd PC, i.e. if you can access 192.168.0.1 (DLink DI-634M) from the 1st PC that is wired.
Should this be the case or the scenario is different, pls post back.
Hope this be of initial help/idea. Pls post back as requested or should you be in need of additional information.
Good luck and kind regards.
Jan 21, 2008 | Computers & Internet
D-Link DI-634M Wireless Router (DI634M) Logo
183 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
