Question about GE Profile Spacemaker Over-the-Range Microwave
Micro doesnt heat - GE Profile Spacemaker Over-the-Range Microwave
  • 3,037 Answers
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Posted on Aug 20, 2010
  • Robert Caraway Sep 06, 2011
    I am not sure I agree with the financial assessment above. Replacing GE built in microwaves runs $1800-2500. A magnetron costs between $100-180. You do the math for your self.
    Counter top microwaves are cheap, unlike the built in versions and I am not sure why that is.
Microwave wont heat?
door interlocks micro switches
a duff relay on the control board
bad magnitron heaters {connections inside come adrift }
bad EHT to the magnitron
Aug 12, 2014 | Microwave Ovens
Microwave doesnt heat
Typically, this is a failure of the door safety interlock switch. Remove the cover, check the tiny micro switches for proper action. You will need a volt/ohm meter or contunity checker to do this. Make sure the power is off when you check this.
Sep 19, 2011 | Electrolux Microwave Ovens
Eveything seems to work on this unit but it doesnt heat the food?
Chance is the Magnatron is at fault ,check first replace if need be the thermal fuse....Magnatrons are the main part that goes after some 5 years replacement is quite expensive,cheaper to buy new micro...
Feb 23, 2011 | Kenmore Microwave Ovens
Our Oster microwave operates normally, but it doesnt heat the food at all. ?
Please remove the cabinet and check the door safety interlock switches. Micro switches near the door latch assembly are #1 to failure because we open the door to check whats cooking while the machine is running. The tiny contacts arc and eventually burn. Then they are not able to tell the oven the door is closed, the magnetron is not turned on ... no magnetron ... no heat. Get replacemente at electronics parts store near you or from a FixYa.com advertiser.
Thanks for visiting FixYa.com
Dec 26, 2010 | Oster 0.7 Cu. Ft. Compact Microwave
The oven makes a loud humming noise when turned on, doesnt heat food, everything else works
This is most likely a bad magnetron, but it could also be a bad high voltage diode.
I would check out this website
http://www.applianceaid.com/micro.html
Or you could call a local Appliance Repair Technician
Dec 10, 2010 | Kenmore 62642 / 62644 / 62649 Microwave...
Unit turns on, turntable turns, but nothing heats
Classic symptoms for failed door interlock safety switches, though it could be other trouble.
Remove the cover and check the operation of the little micro switches that operate when you close the door.
DONT TOUCH THE SILVER CAN - LETHAL.
If you regularly open the door while cooking, the contacts in these little switches become burned. When burned badly enough, they cannot make contact. When they cannot make contact, the mocrowave doesnt know the door is closed and will not turn on the magnatron resulting in no heat.
If you need more help, let me know.
a
Sep 27, 2009 | LG LRM1250 Microwave Oven
GE Spacemaker Micro
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
srtat
Jun 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
My microwave doesnt work
good day, try to check your cooking settings. tnx
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
400 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
