Wireless mouse stops working. Untilthe top button is pushed then it works for a short time.
Your top button might be a reconnect... I had a similar problem with a new keyboard mouse combo, I even purchased a new set and it turned out to be a speaker was too close to the USB receiver. When in regular windows it would stutter a bit but during games after a while it would just shut down. I figure this is because games used the speakers more idk Moved the speaker no more problem thus far.
Posted on May 19, 2009
  • 197 Answers
If i understand that you have to push the left button and works, it sound like there is something wrong internally, my suggestion is to buy a new one so you dont have go throught pushing the top button any more.
Posted on May 03, 2008
How do i get the short cut buttons to work
Device downloads
Click the link to download the Manual and Drivers for the Microsoft Wireless Laser Desktop 4000.
The top row functions (Help, Undo, Redo, etc.) are on the same keys as F1, F2, etc. You toggle them with the "F Lock" button on the top right of the keyboard.
All the "extra" buttons will need the proper device driver to function entirely.
Jul 12, 2017 | Microsoft Wireless Laser Desktop 4000...
I have a compucessory wireless mouse and keyboard. Mouse model 40918. My mouse just stopped working this morning. How do I get it to reconnect?
check the batteries on the mouse
usually on the underside of a mouse possibly under a plastic sticker rub your fingernail across the top to locate a small (phillips screw) star screw make sure they are connected you can do this by spinning them around and fully charged
hope this heps
Oct 25, 2011 | Compucessory Wireless Optical Mouse...
It stopped working, the keyboard is working fine. Replaced the batteries still not working?
When you change batteries you also need to reset your mouse and the receiver.
Back on your mouse is a little connect push-button to reset your mouse.
Eventually also push the black button on the top of the receiver.
This will hopefully help.
Regards
Sep 07, 2011 | Microsoft Wireless Laser Mouse 5000
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
My wireless mouse stopped working; I changed the batteries and still no light. Can you suggest a solution? I tried the connect button but no change. Thanks for any help!
usually there is a button on the bottom of the wireless mouse that you can push at the same time you push the button on the mouse adapter on the pc. Simulataneously push both and see if that doesn't help.
If that doesn't work, change batteries. If that doesn't work, uninstall the mouse and reboot. Software should reinstall.
Jul 06, 2010 | Logitech Cordless Mouse
Dell wireless mouse
I had this problem, but only when my batteries were dead. Check the contacts on the batteries to make sure they're working. Are all the buttons failing too? It might be a broken microswitch (or whatever they use these days). It sounds like you're looking at a new mouse if it's not contacts. Unless someone else on this forum has different ideas.
Nov 04, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Wireless mouse problem
Try this:
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jun 25, 2008 | Dynex Wireless Optical Mouse DX-WOM100
Key tronic wireless mouse quit working
Sounds simply broken to me. Time for a new mouse.
May 23, 2008 | Key Tronic UNPLUGGED PS2SB01...
Microsoft wireless intelimouse explorer 2.0
Having experienced the same problem with (2) Intellimouse Explorers I analyzed the problem and found a solution after driver updates failed to correct it.
Remove the single screw inside the battery compartment, lift off the rear portion of the mouse top cover, then gently lift up the back end of the remaining shell.
Once you have the inner workings exposed, use a Q-Tip to dab rubbing alcohol on the right click button's micro switch, manually clicking it a couple dozen times to clean the button's inner workings. Do not work about shorting out the mouse, as alcohol is non-conductive, and non-corrosive. It will not harm the electronic circuitry.
It doesn't hurt to do the same for the left click micro switch and the side button switches as well, as long as the mouse is disassembled.
Next use a clean Q-Tip to clean the edges of the top & bottom housing. This is the most likely cause of the right click button failure - there are small particles of debris lodged along the edge where the travel of the right click button is supposed to depress, but cannot.
Next, turn the top cover over and move the catch on the right underside forward and push it gently downward to uncatch the edge of that latching clip. The click on the left underside is a bit more complicated and requires a gentle lifting of the rear pins and moving the left clip more to the left and downward to release it from it's locking position.
Once you have freed the actual button's cover from the rest of the top cover, clean it thoroughly with a Q-Tip swab soaked with rubbing alcohol.
While the works are exposed, check for hair and debris around the scroll wheel as well. The small plastic wheel cover lifts off starting from the read and tipping up and forward.
Carefully reassemble all parts and hte right click function should now be restored. The debris has been removed and the right click now has it's full range of travel restored.
Apr 29, 2008 | Microsoft Wireless IntelliMouse Explorer
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
