Question about Sport & Outdoor - Others
What size line fits a shimano fx200? I want to know how much 4 lb, 6 lb or 8 lb line fits according to manufacturer.
5 Suggested Answers
godspeed808
  • 125 Answers
SOURCE: size of fittings.
youll need a tube wrench 10mm to remove them -8 lan fittings
Posted on Feb 06, 2009
SOURCE: Size of fittings on lines
What is the issue with the cooler pipes/lines? Thread Size,Wrench Size?
Posted on Mar 16, 2010
ftw1952
  • 10319 Answers
SOURCE: 1994 Honda Accord EX 4
they are metric and different sizes were used that year. Get a metric thread sizer at any auto parts store or Sears to determine the correct thread size
Posted on Jul 07, 2011
jamessizer81
  • 7515 Answers
SOURCE: Compression 160 lb on 1/3/5 no compression on 2/4/6 timing marks are lined up.
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Posted on Jan 09, 2017
Fitting instructions needed for Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
The semi-circular spacer is what holds the derailleur in the dropout. Take the part that looks like a "C" and line it up on the drop out, the spacer goes on the other side of the dropout. There should be a screw that fastens to the spacer and clamps the derailleur to the drop out.
Apr 14, 2014 | Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur...
What the maximum working torque for a Ingersoll Rand 1/2 2705P1?
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
Mar 28, 2011 | Ingersoll Rand Air Tools & Compressors
What kind of components do I need?
Most bikes have Shimano shifters & deraillers; SRAM is the other main vendor. Shimano makes a wide range; the following table attempts to describe these and presents my best guess of where the SRAM line fits in: Model Quality SRAM Equivalent?
SIS, Tourney (or just says Shimano) Mainly designed for riding around the neighborhood
Altus Sufficient for paved or very easy trails; avoid hills 3.0
Acera Slightly better, but won't shift well under stress; capable for easy casual riding 4.0
Alivio Minimal capable for recreational riding; will handle some hard riding 5.0
STX / Deore Entry-level components for hard riding; tough & reliable 7.0
LX The minimum standard for hard riding. Reliable & responsive 9.0
XT More responsive than LX, but still reasonable tough 9.0SL
XTR Light, responsive racing components; tend to be quite expensive; often sacrifices toughness for responsiveness X.0
Look for a component set that fits your expected riding style.
Note:The numbered SRAM components aren't compatible with Shimano components. SRAM does make grip-shifters that are Shimano-compatible.
There are many other manufacturers that specialize in various components (Avid, Cane Creek, Race Face, Hope) and make great ones. Ask the LBS personnel for a comparison if you see a brand you don't know. Also, you can use the same test as forks above: if its not sold separately, its probably more questionable. If you're getting a full-suspension bike, make sure you get a good rear shock as well (it'll probably be something other than SRAM or Shimano).
Dec 16, 2010 | Cycling
Shows out of paper. Says paper jam. Open door . Clear carriage. Press ok. Cannot solve problem!!! 75 years old with 1st computer!
Out of paper
Cause: There is not enough paper in the input tray.
Solution: If the HP All-in-One is out of paper or there are only a few sheets
remaining, load more paper in the input tray. If there is paper in the input tray, remove
the paper, tap the stack of paper against a flat surface, and reload the paper into the
input tray. To continue your print job, press OK on the control panel of the HP All-in-
One.
Cause: The rear door is off the HP All-in-One.
Solution: If you removed the rear door to clear a paper jam, replace it.
rear door.
Paper can also jam in the automatic document feeder. Several common actions can
cause paper to jam the automatic document feeder:
• Placing too much paper in the document feeder tray. For information on the maximum
number of sheets allowed in the automatic document feeder, see Technical
information.
• Using paper that is too thick or too thin for the HP All-in-One.
• Trying to add paper to the document feeder tray while the HP All-in-One is feeding
pages.
To clear a paper jam from the rear door
1. Press in the tab on the left side of the rear door to release the door. Remove the door
by pulling it away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Paper specifications
This section contains information about paper tray capacities, paper sizes, and print margin
specifications.
• Paper tray capacities
• Paper sizes
• Print margin specifications
Type Paper weight Input tray1 Output tray2 Document
feeder tray
Plain paper 16 to 24 lb. (60 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 35
Legal paper 20 to 24 lb. (75 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 20
Cards up to 110 lb.
index (200 gsm)
40 10 N/A
Envelopes 20 to 24 lb. (75 to
90 gsm)
15 10 N/A
Transparency film N/A 25 25 or fewer N/A
Labels N/A 20 20 N/A
4 x 6 inch photo
paper
up to 145 lb. (236
gsm)
30 10 N/A
8.5 x 11 inch photo
paper
N/A 40 20 N/A
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using.
HP recommends emptying the output tray frequently.
Paper sizes
Type Size
Paper Letter: 216 x 280 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Chapter 15
266 Technical information
Type Size
Legal: 216 x 356 mm (8.5 x 14 inches)
Envelopes U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. #9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Premium photo paper 102 x 152 mm (4 x 6 inches)
A4: 210 x 297 mm
Cards A6: 105 x 148.5 mm
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Custom 102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14
inches)
Top (leading edge) Bottom (trailing
edge)
Left and Right
margins
U.S. Letter
U.S. Legal
A4
Photo media
1.8 mm (0.07 inches) 2 mm (0.12 inches) 2 mm (0.12 inches)
U.S. Executive
B5
A5
Cards
1.8 mm (0.07 inches) 6 mm (0.24 inches) 2 mm (0.12 inches)
Envelopes 16.5 mm (0.65
inches)
16.5 mm (0.66
inches)
3.3 mm (0.13 inches)
Print specifications
• Resolution: 1200 x 1200 dpi black, 4800 optimized dpi color or 6 ink
• Method: drop-on-demand thermal inkjet
• Language: Lightweight Imaging Device Interface Language (LIDIL)
• Print speed varies according to the complexity of the document
(continued)
Print specifications 267
Copy specifications
• Digital image processing
• Up to 100 copies from original (varies by model)
• Digital zoom: from 25 to 400% (varies by model)
• Fit to page, pre-scan
• Copy speeds vary according to the complexity of the document
Mode Type Scan resolution
(dpi)1
Best Black up to 600 x 1200
Color up to 600 x 1200
Normal Black up to 300 x 300
Color up to 300 x 300
Fast Black up to 300 x 300
Try clearing all paper from all carriages (Top,Rear, Front, etc. then reinserting proper amounts. Even the smallest piece of paper can cause a jam. Here is a user manual in case you don't have one you can get it here: http://h10032.www1.hp.com/ctg/Manual/c00844812.pdf
This is a PDF and it is searchable and easy to navigate (Red lettering will take you to that section), so you will need Adobe Acrobat Reader (if you don't already have it you can get free here:
http://get.adobe.com/reader/
Also, once you have done all you can turn the printer off for a moment then turn it back on.
Hope this helps. Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | HP Officejet J5780 All-In-One InkJet...
What size our the speakers in the back doors
Car speaker fit guide - CHEVROLET BLAZER S-10 2001
According to our database, here are the speakers types that go in your CHEVROLET BLAZER S-10 2001 car, along with their location:
  • Front: 4" x 6", 6-3/4"
  • Rear: 6-3/4", 6" x 9"
  • Dash: 4" x 6"
  • Front door: 6-3/4"
  • Back door: 6-3/4"
  • Rear side panel: 6" x 9"
Oct 04, 2010 | 2001 Chevrolet Blazer
I need a diagram of a 1995 ford escort engine
96 escort 1.9L
Engine Components
Item Part Number Description 1 6766 Oil Filler Cap 2 6A548 (8 Req'd) Valve Cover Bolt 3 6582 Valve Cover 4 — Exhaust Manifold Shield-to-Exhaust Manifold Nut (4 Req'd) 5 9A462 Exhaust Manifold Shield 6 — Exhaust Manifold Shield Stud (4 Req'd) 7 9430 Exhaust Manifold 8 9454 Exhaust Manifold Nut 9 9448 Exhaust Manifold Gasket 10 — Exhaust Manifold Stud (Fine Thread), Short (4 Req'd) 11 — Exhaust Manifold Stud, Long (1 Req'd) 12 — Exhaust Manifold Stud (Medium Thread), Short (1 Req'd) 13 6518 Valve Spring Retainer Key 14 6514 Valve Spring Retainer 15 6513 Valve Spring and Damper, Intake 16 6C515 Valve Tappet Guide Plate Retainer 17 6571 Valve Stem Seal 18 6513 Valve Spring, Exhaust 19 12405 Spark Plug 20 6269 Camshaft Thrust Plate 21 — Camshaft Thrust Plate Bolt (2 Req'd) 22 — Cup Plug 23 6B273 Camshaft Oil Flow Control Rod 24 6K292 Camshaft Front Seal 25 6256 Camshaft Sprocket 26 6278 Camshaft Sprocket Washer 27 6K252 Camshaft Sprocket Retaining Bolt 28 6L269 Camshaft Sprocket Key (5 x 18) 29 6250 Camshaft 30 6051 Head Gasket 31 6A008 Cylinder Head to Block Dowel 32 6010 Cylinder Block 33 6507 Intake Valve 34 6505 Exhaust Valve 35 6049 Cylinder Head 36 — Intake Manifold Stud (7 Req'd) 37 17A084 Engine Lifting Eye 38 — Engine Lifting Eye Bolt (2 Req'd) 39 9439 Intake Manifold Gasket 40 — Bolt 41 9723 Accelerator Cable Bracket 42 9424 Intake Manifold 43 — Intake Manifold Nut (7 Req'd) 44 9D476 EGR Valve Gasket 45 — Exhaust Gas Recirculation (EGR) Valve Bolt (2 Req'd) 46 9D475 EGR Valve 47 — Fuel Injection Supply Manifold Bolt
(2 Req'd) 48 9F593 Fuel Injector 49 9D930 Fuel Charging Wiring 50 6786 Oil Level Indicator Tube Bracket 51 — Oil Level Indicator Tube Bracket Bolt 52 6754 Oil Level Indicator Tube 53 6750 Oil Level Dipstick 54 9D280 Fuel Injection Supply Manifold 55 — Vacuum Fitting 56 9E498 Main Emission Vacuum Control Connector 57 — Vacuum Tap 58 — Vacuum Hose 59 9B989 Throttle Position Sensor 60 — Screw and Washer 61 9F782 Throttle Position Sensor Gasket 62 — Throttle Body Bolt (4 Req'd) 63 — Idle Air Control (IAC) Valve Bolt
(2 Req'd) 64 9F715 Idle Air Control Valve 65 9F670 Idle Air Control Gasket 66 9E926 Throttle Body 67 9E936 Throttle Body Gasket 68 — Vacuum Fitting 69 — Camshaft Position Sensor Screw 70 6B288 Camshaft Position Sensor 71 8255 Water Hose Connection Gasket 72 — Water Hose Connection Bolt (3 Req'd) 73 8592 Water Hose Connection 74 8575 Water Thermostat 75 6065 Cylinder Head Bolts 76 6500 Valve Tappet 77 6K512 Valve Tappet Guide Plate 78 6564 Rocker Arm 79 6A528 Rocker Arm Seat 80 6A527 Rocker Arm Bolt (8 Req'd) 81 — Ignition Coil Mounting Bracket Bolt
(3 Req'd) 82 18827 Noise Filter Condenser 83 — Ignition Coil Mounting Bolt (4 Req'd) 84 12259 Spark Plug Wire Set 85 12029 Ignition Coil 86 12043 Ignition Coil Mounting Bracket A — Tighten to 5-12 Nm (4-9 Lb-Ft) B — Tighten to 5-7 Nm (3-5 Lb-Ft) C — Tighten to 21-26 Nm (16-19 Lb-Ft) D — Tighten to 2-10 Nm (1.5-7 Lb-Ft) E — Tighten to 8-13 Nm (6-9 Lb-Ft) F — Tighten to 40-55 Nm (30-41 Lb-Ft) G — Tighten to 16-20 Nm (12-15 Lb-Ft) H — Tighten to 20-30 Nm (15-22 Lb-Ft) I — Tighten to 8-10 Nm (6-8 Lb-Ft) J — Tighten to 8-11 Nm (6-9 Lb-Ft) K — Tighten to 23-30 Nm (17-22 Lb-Ft) L — Tighten to 20-40 Nm (15-30 Lb-Ft) M — Tighten to 4.5-7 Nm (3-5 Lb-Ft) N — Tighten to 18-26 Nm (13-19 Lb-Ft)
Feb 24, 2009 | 1995 Ford Escort
Need to know the physical size of a battery for a 1996 Cherokee.
Your Jeep Grand Cherokee uses a group 34 type battery. The sizes vary from manufacturer to manufacturer but, the standard size is 10 1/4 " x 6 13/16" x 7 7/8" or 260mm x 173mm x 200mm. Anything close should fit fine. Good luck. Please ask for help any time. Please rate me so I know how I'm doing. Thanks
Dec 30, 2008 | 1996 Jeep Grand Cherokee
What size speakers are in 1999 Dodge Durango
Car speaker fit guide - DODGE DURANGO 1999
According to our database, here are the speakers types that go in your DODGE DURANGO 1999 car, along with their location:
  • Front: 6-3/4"
  • Rear: 6-3/4"
  • Back door: 6-3/4"
Dec 17, 2008 | 1999 Dodge Durango
I need to know what my vin number means.1j4gz58s4pc121933
General Information VIN 1J4GZ58S4PC121933 VALID Passengers 0 Date 12/12/2008 Year 1993 Doors 0 Invoice $19,195.32 Make Jeep Manual/Auto Trans. No/ No MSRP $21,114.00 Model Grand Cherokee Forced Induction No Delivery $495.00 Trim Laredo FrontWD No Engine Type Straight 6 Cylinder Engine Style 4-Door Laredo 4WD RearWD No Engine Size 4.0L/242 CID Market 4WD Special Purpose Vehicles AllWD No Horsepower Towing 0 - 6,000 FourWD No Torque Fleet Only No Stepside No Fuel Type Gasoline Fuel
Dec 12, 2008 | 1999 Jeep Grand Cherokee
Max Paper Weight
Here ya go...
Tray 1: (standard) 16 lb. Bond – 80 lb. Cover (60 – 220 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, business cards, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards, Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, A5, A6, B5 JIS, B5 ISO, 3 5 in. Index Cards, custom sizes; Envelopes: #10 Commercial, DL, C5, #5 , #6 , Monarch, Booklet, Lee (A7), Choukei 3 Gou, Choukei 4 Gou, custom.
Tray 2: 525-sheet tray (standard) 16 lb. Bond – 28 lb. Cover (60 –122 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards,Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, B5 JIS, B5 ISO; Envelopes: #10 Commercial, DL, and C5.
Tray 3: 525-sheet Feeder (standard on DX) Same media weights and sizes as Tray 2.
Tray 4: 525-sheet Feeder (optional) Same media weights and sizes as Tray 2.
Nov 12, 2007 | Xerox Phaser 8400 Laser Printer
Sport & Outdoor - Others Logo
123 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
