Question about Motorola Mobility H700 Wireless Headset
Motorola h700 Pin code 0000 wont work on Motorola phone.
  • 487 Answers
Try 1234 that is normal for motorola
Posted on May 03, 2008
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Pin # for h700 bluetooth
pin for this Motorola bluetooth is '0000'.
Jun 02, 2009 | Motorola Mobility H700 Wireless Headset
Pin code
If it is your first time using it usually the code is 0000 otherwise look through the manual and call for asistance, if that dosent work go somplace like springfeild mall and then to a cellular phone service center.
Jan 10, 2009 | Motorola Mobility HS850 Consumer Headset
I accidentally deleted my blue tooth from my phone, and now I can't remember the pin code. It is a motorola H700
Hi there, try 0000 or 1234. These are the default. Otherwise you should do a full reset by going into settings. If that does not work, you should take it to a repair centre.
Jul 28, 2008 | Motorola Cell Phones
Code doesn't work!
space.gif I took this off Motorolas website. question.gif What's the pairing pin code and can I change it?
space.gif space.gif answer.gif The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
Are you holding the button on the bluetooth till it turns purple. If not then it wont sync properly. After the Bluetooth turns purple then go to your phone and have the phone look for devices. Check this wbsite for pairing instructions
http://www.motorola.com/mdirect/demos/how2_h700/main.html
Jul 22, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 Bluetooth Headset
The password is on the H700 and can't be changed. It is 0000 (that is 4 zeros).
May 24, 2008 | Motorola Mobility H700 Wireless Headset
Connecting phone with h700 headset
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Jan 05, 2008 | Motorola Mobility H700 Wireless Headset
Pin code
set up your phone to search for BT devices, press and hold the phone button on your Skywing or H700, once the purple light comes on open the boom. Your phone should see the device. When prompted for a passcode enter 4 zeros, if that doesn't work, try 5 zeros, if still no luck try 1234 and 12345
Oct 29, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
52 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
