Question about Whirlpool Duet GHW9150P Front Load Washer
I received an error code of F-21 on my washer machine. Help!!!!! It will not spin or drain the water
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
The "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process, hence it cannot spin correctly either.
Chances are the pump is being obstructed by debris or some other foreign object.
Here`s how to check it and clean it...
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removeable filter. ( this is were a shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet ) 3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removeable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to varify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the drain hose, hose from pump to tub for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
macmarkus :)
Posted on Aug 20, 2010
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
CODE F-21 NOT SPINNING THE WATER OUT when it comes to the rinse cycle . IT MAKES A CLICK SOUND AND STOPS . THEN IT SHOWS CODE F-21
The machine is not spinning the water out because there's a problem with the drain system as the error code indicates. Either the drain hose is clogged or kinked, the pump filter is blocked, the pump impeller is blocked or damaged or the pump itself is not working at all. The click sound may due to a blocked pump impeller.
Disconnect power and the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter from the pump housing by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 31, 2010 | Kenmore HE2 Plus Front Load Washer
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
F 21 error code I came down with 1 minute estimated time remaining, and it was still spinning with soap and water in the machine. I checked again 20 minutes later and the water and soap was still in...
"F21" is a long drain error code. This is most commonly caused by something obstructing the drain pump, or drain lines. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
I would begin by checking the drain pump reservoir for small debris. You would be amazed as to what finds its way into these pumps. The link I provided also gives instructions on how to check the drain pump.
If you clear the drain pump and the problem still presists, verify all the drain lines are clear. If all these preliminary checks still result in an error code, more than likely the drain pump is damaged and requires replacement.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Has F error & won't drain & spin
I agree a F code of 21 or 2 I would clean the pump and check the bellow behind as well the pump entry from the trap for debris or a broken impeller.
Sep 08, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
