Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
No picture my jvc powers on, but no picture, makes a noise
  • 2 more comments
  • Sandraj May 03, 2008
    solid blue light
  • Anonymous Feb 02, 2009
    tv comes on ,sound/black screen no picture?
  • paulpenajr13 Feb 02, 2009
    tv comes on ,have sound/black screen no picture
    tv,sound/no picture,black
No picture /have sound tv comes on
Posted on Feb 02, 2009
    Scholar:
  • 173 Answers
Alot of sets turn solid blue when the signal is lost . check your antenna or cable inputs might be chewed up by pets mostly.
try feeding in a dvd player, or VCR signal and see if that plays on channel 3 or 4 ... if not you might need a new tuner.
Posted on May 10, 2008
Tv making thumping noise
Since you did not mention model number, then depending on year, it is probably time to replace the TV. They are almost disposable these days; meaning cheaper to replace than to repair.
Feb 09, 2018 | JVC Televison & Video
I have a JVC AV-65WP74, I went to bed watching the TV then turned it off for the night but the next day when I turned it back on the blue light came on on the TV but no picture, the TV makes a fast...
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
May 19, 2011 | JVC AV-65WP74 Rear Projection Television
Good Morning\r\n i have a JVC Interiart 29" Flat screen tv which is 8 years old which has started making a noise when switched on,a very loud humming noise and no picture for a couple of minutes then the...
That usually indicates a capacitor going out in the power section or flyback section of the board inside. Depending on your repair shop this can be a fairly cheap repair (or not). Get an estimate and know what a replacement tv is worth. Sometimes its cheaper to get a new one than repair the older tv. As well power problems can stress other parts so it might get fixed only to fail later.
Jun 14, 2010 | Televison & Video
Clicking on the power supply board(no picture or sound)
If you hear a buzzing, humming or rapid clicking noises this could be a problem with your ballast.Might be a good idea though to pull out your lamp just ensure its not damaged.You can find these at discount-merchant.com
Apr 01, 2010 | JVC AV-48P575 48" Rear Projection...
Tv won't turn on ... only makes a clicking noise
i have a jvc 1060p and when i try to turn it on there is no picture and it makes this buzzing noise. And then it turns itself off and the power button blinks off and on.
Jan 04, 2010 | Daewoo Televison & Video
Makes a poping noise out of the speakers when i turn it on? can ya help plz thnks james
If you have no video and its making a popping noise its mostlikely shorted convergence circuits. Contact www.TvRepairKits.com and ask them to make you a kit for chirping sets.
May 16, 2009 | JVC AV-48WP30 48" Rear Projection...
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-65WP74 65 in. Rear Projection... Problem:
I'm having a problem with my JVC 65WP74 the screen shows double pictures at the top and in the middle.
Oct 10, 2007 | JVC AV-65WP55 65" Rear Projection...
Jvc 48" tv model av-48wp34
Sounds like you lost the High Voltage. The beating sound is the power supply trying to start up. After a predetermined time it will quit to protect the set. This is a very common problem and typically not that much to repair. If you are not an electronics repair technician you should find a reputable repair shop and enlist their services. I would not think the cost should exceed $150.00 to repair. Good luck.
Jun 18, 2007 | JVC AV-48WP30 48" Rear Projection...
High pitched noise
There is a singing coil in the power supply. This set uses whats called a Switch Mode Power Supply(SMPS) and as the picture changes, so does the amount of current the TV draws. Thats why the sound changes with the picture. This could be an indication that a part is going to fail soon or it is just a loose coil winding or a transformer winding. You should have the set checked out by a pro to be sure. Good Luck
Mar 22, 2007 | JVC HD-52G786 52" Rear Projection HDTV
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
