Question about Gateway FPD1975W 19" LCD Monitor
Wont power up power light just blinks - Gateway FPD1975W 19" LCD Monitor
  • 11,361 Answers
First thing to look will be bad caps in the power supply, they should be replaced as a set if you find one bad one.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 20, 2010
My runco tv wont power on has blinking red light
Could be an open internal fuse or power supply failure
Dec 31, 2017 | Runco Televison & Video
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
99 olds will not start
What have you checked so far ?
Jul 15, 2013 | Cars & Trucks
Power light blinking paper wont feed through
Unplug the power cord from the printer (top left side). Hold the paper feed button while plugging the cord back in.
Jun 29, 2010 | VeriFone 900 Printer
Power went out now the tv wont turn on, there is just a blinking
Does the power light just blink? Some of the Mitsubishi sets have a receiver built into them; if the power is removed the power light upon return of power should blink for 70 seconds and then go out--then the set should turn on---if the light never stops blinking---2 possible things--set should have a recessed button on the front keyboard(reset) that you can depress with something not sharp and see if after 70 seconds the light will stop blinking; if no, the set now has a damaged receiver(from the back of the set it is a large metal box on the far left side-----the blinking power light is the receiver trying to boot up like a computer---only should happen if power lost---let me know what you find----the receiver if bad is usually no longer available and can only be repaired by removing it and sending out for repair/rebuild.
I do this here for free so if this information helped you take a minute and give me a vote here......ALSO IF YOU HAVE ANY QUESTIONS OR NEED HELP REPLY TO THIS POSTING.
SD TECH
Sep 07, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Blinking light
It could very possibly be ur power supply,mine did the same and we changed it out with a spare and it came right on
Mar 25, 2008 | Computers & Internet
Gateway FPD1975W 19" LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
