Question about Magic Chef Ovens
Hey my oven wont turn on, the burners work tho can you help me please?
  • 443 Answers
Check for the correct voltage at the receptacle behind the range where you plug the range power cord in, you should have 220 volts
at the receptacle, it is somewhat common for wires to burn in two at that point.Also, check for the correct voltage at the terminal block on the back of the range where the cord wires onto the range, look for burnt wires there also.
Don't forget to double check that your circuit breakers or fuses are good.
GOOD LUCK !
Posted on Aug 20, 2010
My broiler works but oven is not heating. Is this an ignitor problem?
That could be a good analysis---
Here is an observation you can make thru the oven door:
When you turn the oven on to BROIL-- do you see the bright glow of the ignitor?
(It is almost like a light bulb was in there-- buy the burner!)
When you start the oven (on BAKE) setting-- do you see a similar bright glowing light?
(Tho down lower, near the Lower Over Burner)
If you see the bright light-- then the ignitor is apparently heating up--
If not-- then, YES-- you are likely right--
Ignitors are fairly common failure items-- and they can obviously stop the burner from lighting-
Make sense?
Let us know if we can help further.
Mack B
Jan 15, 2011 | GE Ovens
Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Oven glow plug on but oven wont light , dosnt get hot , top burners work fine. broiler also dosnt work . oven about 13 yrs old
if ignitor glows and the burner does not fire within 30-60 seconds it is weak (not drawing 3.5 amps or higher) and should be replaced. Hope this helps,please rate my solution
Jun 26, 2009 | GE JGRP17 Gas Single Oven
Gas range won't work
Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
If I can help further, please let me know.
Thanks
Vic
May 15, 2009 | Magic Chef 9122 Gas Single Oven
Gas oven not working pilot light is out
1 of 2 things will normally happen and most of the time both things will break. You have two main componets that will wear out 1)your igniter 2)the gas burner tube. Usually what will happen is the gas burner tube allows gas to come out of 3 very small holes-over time and with help from grease, the 3 small holes will turn into a large hole and will allow too much gas to come out and it will destroy your igniter also. Luckly RepairClinic.com sells both pieces in a kit. You can check you igniter with multimeter for continuity (if it is broke-safety kicks in and wont allow gas to work).
May 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Maytag65300ddS My burners wont turn on,. Clock
Sounds like an open connection between the supply circuit and the burners. Could be corroded, burned, broken, or just loose. Also could be a bad/cracked resistor in the same circuit.
I suggest a service call.
Apr 21, 2009 | Maytag MEW6530D Electric Single Oven
Burners and oven wont get hot and light wont come on
The input power is incorrect. The neutral connection may be missing
May 22, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
67 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
