Question about Fujitsu Siemens LifeBook E4010 Notebook
I start the computer goes through normal set-up, but screen is black
    Sergeant:
  • 238 Answers
Check your power cord & adapter. If its working then check the battery, reseat the battery & check. If available then check with another battery If no, then remove the battery & switch on the PC in AC mode. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. If still no display, connect an external monitor, check if display is comming. If Display is coming then your LCD need to replace.
Posted on Aug 20, 2010
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
Y compaq pressario v2000 goes from black screen to intermittent normal screen. The black screen is on the computer 80% of the time and then the pics fade in and out
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
Nov 20, 2012 | Computers & Internet
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
Acer aspire one
Unplugg any external device and restart the computer. If still not, Click on F2 as soon as the computer restarts.. It will open BIOS, press F9 & then F10. Restart the computer.
Mar 17, 2010 | Acer Aspire One PC Notebook
Windows starts to set up then screen goes black and
9 times out of 10, the finger points to the power supply.
Replace it and try again - I reckon you'll be good to go!
Apr 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
No Signal when desktop wants to load
It does not hate that monitor. I believe the problem is in the settings on your video. Your monitor cannot display them. You will most likely need to start your computer in safe mode and change the display settings on your video card or, alternatively, download updated video drivers. Also, if you can't get Windows to start in normal or safe mode, one of the options you get when you press F8 on startup is to start in VGA mode. That will get you in so you can tweak your settings, which are probably set to a resolution too high for your monitor.
Sep 11, 2008 | ViewSonic VA1916w LCD Monitor
Start up problem
option1:- choose the option called safe mode. the first option. just log in and stay for a while in there and restart your computer.
option2:- choose the option start up windows normally.
Jun 18, 2008 | Compaq Presario 700 470024-192 Notebook
My PC will only start and stay on in safe mode. When I start windows normally, it stays on for 5-10 mins then goes to a Black screen....WHY????
It may be going into sleep mode. When the screen goes black, try pressing the space bar on the keyboard to wake it up. If the computer wakes back up again, then you may need to adjust your power settings. Try it and let me know what happens.
Apr 21, 2008 | Computers & Internet
Screen problem
click start button
click controlpanel
click classic view
double click power options or settings depending on your operateing system.
If you have xp, change the time settings for suspend, hibernationg and so on.
If you have vista.
click on change plan settings on your current plan
change the time on: put the computer to sleep.
If you need more asistance, let me know.
Mar 12, 2008 | HP Compaq nx6310 Notebook
Fujitsu Siemens LifeBook E4010 Notebook Logo
421 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
