Question about MotorGuide Boating
I have a motor guide trolling motor pro series 6700 and had to replace the batteries in the boat. how do you connect the wires to the batteries when you have a red a wire, a orange b wire, and a black (neg) wire.
  • 10865 Answers
SOURCE: Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Posted on Jan 18, 2009
  • 4 Answers
SOURCE: Need to know how to wire a motorguide 767 brute trolling motor
The white wire is the ground. The black wire is neg. and the red wire is pos.
Posted on Apr 30, 2009
  • 53 Answers
SOURCE: I just bought a 74 lb Minn Kota trolling motor
I have uploaded a image of the wire system. folllow it carefully. the fuses rating should be no more than than thirty amp. go to your local outboard dealer they sell inline breakers that are designed for trolling motors. i prefer them because you don't have to replace them after a overload. you just reset the breaker.de79e02.jpg
Posted on Nov 04, 2009
SOURCE: I have a 1999-model Minn-Kota bow-mount trolling
55 is a 12 volt system northland marine has diagram.
Posted on Jan 29, 2010
agent91
  • 2100 Answers
SOURCE: 24 volt trolling motor wiring
Just like a flashlight. Positive to neg, In a loop going to the motor. That is the jump between the batteries, One red wire coming in from motor, it will go to pos, from one battery, the neg will go to the 2nd battery pos. From the 2nd battery neg will go to the motor. That is it, one jumper connecting the 2 batteries, will create the 24 volts. Hope this helps.
Posted on Mar 23, 2010
Testimonial: "thank you very much "
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Old outboard ground wire melting
1. Short in the trolling motor itself
2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!!
3. Bad/dirty/corroded battery connections
..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
Sep 11, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I don't have any slow trolling speeds. Only fast speeds on my Pro Series 6700 trolling motor. Any ideas? Also, it is a 24 volt system. How do I properly hook up the batteries. The two batteries are...
To hook up to 24 volts you need to join a positive cable from one battery to the source[motor or controller] and the the negative cable goes to the positive of the next of the next battery,then the negative [of battery #2] goes to ground,same for all 24 volt systems.If the slower speeds don't work then the rheostat in the accelerator handle could be at fault,but getting the 24 volts sorted out may fix everything.
Jul 22, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Mar 22, 2010 | Boating
How to attach leads to batteries
This is what they call a series connection. The two 12 volt batterys are wired together in a series to make one 24 volt battery. The positive wire or red from your trolling motor goes to the positive post on battery 1. The negative lead from trolling motor goes to the negative post on battery 2 then there is a short wire that goes from negative on battery one to positive on battery 2. NOW GET THAT HOOKED UP AND GET IN THE BASS.
Nov 29, 2009 | Electrical Supplies
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
Jan 18, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Oct 20, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Boating Logo
32 people viewed this question
Top MotorGuide Boating Experts
Mike
Phil Walker
Phil Walker
Angel Joseph Jr.
Angel Joseph Jr.
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
