Question about Exercise & Fitness
Owners manual for lifegear manual treadmill - Exercise & Fitness
  • Anonymous Mar 16, 2014
    lifegear treadmill rolls and stops after a short while
I have a lifegear treadmill and get an E2 error and the treadmill will not move.
Posted on May 04, 2011
  • Lorna Hart Oct 07, 2011
    I also have a lifegear treadmill and get the same E2 error mesage after the machine has run for bout 30 seconds, There is nothing in the manual and I have tried everything I can think of to reset the machine with no change. Disappointed to discover that the company website does not offer customer service!
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I have a lifegear motorized treadmill. After using
1)Alternative: Elevation Out Of Range
2)tsu3fngh4aaaaasuvork5cyii=
Posted on Nov 03, 2011
I need the Owners Manual for LifeGear 22815 Upright Deluxe Bike
Try Googling (LifeGear)(22815)(manual) without parens.
Aug 13, 2017 | Cycling
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Lifegear Vigor Plus 97700. What does error 2 indicate?
can only suggest you contact the manufacturer .
Oct 31, 2015 | Exercise & Fitness
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
Lifegear treadmill
You might inquire of Lifegear how many watts it consumes
Jun 04, 2013 | Exercise & Fitness
Agent in bahrain.
you must contact to the company supplier for the treadmillss and ask who is the dealer around you. Give you moder, mark, and serial number
God bless you
May 30, 2013 | Exercise & Fitness
Lifegear motion plus 97920 problem
please adjust the REED switch and see the diagram attached. Test for open or faulty. Clean it + tight the connector very well.
2) if you equipment has battery replalce by new ones and clean it, and putt with FULL energy.
3) TIGHT THE RIBBON CABLE for keypads , clean it and try again.
God bless you
Feb 22, 2013 | Exercise & Fitness
I need the I.C number on a Lifegear Walkease Motorized Treadmill # 97295, found out the ic was burnt on the control panel whicl always display E2 code
Dear Sir:
1)In electronics, you must need to get the number of IC.
2)If you get some information like as the number of the Control Panel, will be more easy to find, the I.C.
3) You must shure the why the I.C. was burn? . Normally this problem can occur a) failure for some short of some component around the I.C. b) Power supply +5 or 12 Vdc or Low or Higher( Indicating that power supply is Not Good).
4) Would you please tell the exactly Model, Mark, Serial from your Treadmill? In that way I can help you more, and try to get the Schematic Diagram from your Fitness Treadmill.
Sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 24, 2011 | Exercise & Fitness
Belt slipping
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Mar 12, 2009 | Exercise & Fitness
Exercise & Fitness Logo
1,087 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
