How do i get my laptop to print without the USB port being plugged into the printer?
    Brigadier General:
  • 5,158 Answers
You would need a wireless printer or a printer hooked up to a network.
Posted on Aug 19, 2010
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
Hi i have a Canon MP830 and have replaced all the ink cartridgers and they all light up but my printer wont print,fax,copy.It sounds like it is printing but the pagers come out blank.It won't even send...
Some laptops cannot run some printers or scanners. Make sure your laptop can handle running the printer from a usb port. It might help to have your laptop plugged into AC power. Also, make sure you have the most current printer drivers for your particular OS installed. If your laptop can't run your printer from its usb port, you can probably connect the printer to a desktop usb or a printer port, then print from your laptop through a home network.
Jul 26, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Hello, How do I connect my Epson stylus PHOTO px700 to my laptop?
NETGEAR’s 54 Mbps Wireless Print Server with 4-port Switch allows you to connect one or two printers to your existing wireless network, without using unsightly Ethernet cables. Simply place your printers anywhere in your home or office that works best for you, plug them into the print server’s USB ports, and the Smart Wizard set-up function automatically guides you through configuration. Then you can send your business documents to a high-end color printer, and your kids’ homework to a black-and-white printer. The print server also acts as a wireless Ethernet bridge, connecting a cluster of up to four PCs and laptops without requiring dedicated wireless adapters. I t employs powerful WEP Encryption and WPA-PSK to keep your wireless network secure, and interoperates with all standard b and g wireless devices. All this in a sleek, space-saving stand-up case.
Mar 22, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
Two printers, one computer.
The answer is yes! You can have as many printing deveces as you want. If you are out of USB ports, purchase a USB hub (please plug the printer directly into a USB port to have the device recognized) then load the drivers. If you don’t have the drivers google “epson r2880 driver” and you will be good to go. You will have to select a default printer in ‘Settings’ but you will be prompted each time you print. Happy computing! Doogie
Jan 11, 2009 | Nikon COOLPRINT Thermal Printer
After docking laptop I have to add port prior to printing
I assume you're running Win Xp. Disconnect the USB cable from the docking station. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. Double click on the Konica icon. In the print queue that opens, delete any pending print jobs. Go to START/CONTROL PANEL/ADD REMOVE PROGRAMS. Uninstall any Konica software. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. On the MENU bar, click on PRINTER/SERVER PROPERTIES. Click on the DRIVERS tab. Remove anything that says Konica. Click on the PORTS tab. Remove ALL the Konica ports. Reboot Re-install the printer driver - DO NOT plug in the USB cable until it tells you to. That SHOULD do it. If it does not, please let me know and I'll research it further. Ed
Jul 13, 2007 | Konica Minolta PagePro 1350W Laser Printer
14 people viewed this question
jasbo
jasbo
