Question about Kitchen Ranges
GE dehumidifier 30 pint, Model AHW30LHG1, starts ok, but within 2-3 minutes quits and does not restart unless I remove and reinstall the water tank. Solution?
  • 5 more comments
  • marketing318 Aug 19, 2010
    This appliance is not a kitchen range! It is a dehumidifier
    Well, I'm not brainless, but I have checked all those items and they appear to operating fine, except for the system operating on a continuious timeframe. No help thanks
    As I said the humidifer runs when I first place the water tank in then it only runs for about 2-4 minutes before it quits. Tank never fills up, or even gets moisture in it (not enough time running). What could be the problem?
  • marketing318 Aug 20, 2010
    Aye Aye Captian! Very good! Thanks for the links to the parts diagram (I used to illustrate them) and the close up photograph of the part (company photographer too)! I will give the adjustment procedure you suggested and if that does not work I'll buy a new switch. Worth the $6 and the part price of $12! Thanks!
    Thanks for the information abouot the switch. I will try your remedy tomorrow and let you know how it turns out.
  • marketing318 Aug 22, 2010
    I used cardboard to increase the measurement between the float leaver and the microswitch. It did not work, same situation exsists. I have removed the switch and going to bench check and replace if bad. Adjustment of the switch can not be made. It has one nut to attach it to the body.
    Hey there Kel Guy - I am going to jumper the switch and see if the condition continues. Thanks for sticking with me!
    Pete
  • Kitchen Ranges Master
  • 11,800 Answers
The sensor from the float in the tank is faulty (it constantly signal that the tank is full) - either try to fix it by checking and cleaning the contacts inside it or you will need a new tank
http://www.humidifierfilters.com/search/model.php?modelsID=122216
Posted on Aug 20, 2010
  • 3,740 Answers
Hi and Welcome to FixYa I am Kelly. Check item 14 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5202477&diagram_id=24095824#d24095824
Close up view:
http://mytriggers.com/WK10X10006/search-html
You may have to remove the switch.. back off the rear nut so the plunger is extended closer to the tank when installed and then reinstall the front nut. If it is not adjustable as installed you may have to replace the switch.
The water tank may have indented the plastic where the plunger strikes the tank which will require you adjust the switch.
You can try to tape a piece of cardboard on the tank where the switch striker touches the tank for troubleshooting but I would NOT leave it in place as a permanent fix. (Adjust the switch)
I do not recommend water tank replacement for this problem. (Adjust the switch)
Thanks for choosing FixYa.
Kelly
  • 7 more comments
  • Kelly
    Kelly Aug 21, 2010
    Just following up here. Did the switch recommendation(s) correct the problem? There are other things to check if not. Kelly
    There is no adjustment I can make with the switch, it is out as far as it can go.
  • Kelly
    Kelly Aug 22, 2010
    Just a thought BEFORE you buy a new switch. Try jumpering the two switch terminals together and see if you still have the same problem. If the problem persists it could be the Contacts on the PTC relay or KilXon thermal overload on the compressor that are heating up rapidly and not providing enough amperage for the compressor to run. (Very common issue) There is more we can check if the symptom repeats. I will stick with you on this.
    Kelly
  • Kelly
    Kelly Aug 23, 2010
    I am just one of those people that refuses to tell someone to go off and buy a part that they don't need. I always make certain that the part is defective before telling someone to make a parts purchase. However... if we have the same symptom repeat we may be faced with the purchase of the thermal overload and PTC relay assy. We could have a situation where the compressor is only running on the start winding until the thermal overload trips EVERYTHING off. That is caused by a thermal overload / PTC Relay problem and you do not change just one part you change them both.
    Kelly
  • marketing318 Aug 23, 2010
    Kelly, It is good that you refine your posts to make sure I do not have to needlessly buy a part. I tested the switch with a multimeter, set on ohms and it checked out ok. The meter read 0, then 1 after engaging the switch. I would assume jumping the wires would produce the same problem I have been experiencing. Any further checks to the thermal overload or PTC relay?
    Pete
  • Kelly
    Kelly Aug 23, 2010
    The only test you can do is a power test with the meter while the unit is running. If you never lose power and the unit shuts down you know you have on this particular compressor a thermal overload problem The thermal overload in the parts break down of this link is (Item 28): http://www.appliancepartspros.com/partse...
    Let me back up and regroup here.. the compressor is a scroll type compressor and the relay for the compressor appears to be on the main board.
    If during the running voltage test you actually lose power then I would start looking at the sensor assy (item 13) of the above link.
    Look at the parts link. There is an envelope inside the unit that is item 9999 in the parts link. That should be the unit data sheet. It may help you with checking out the sensor assy. I do not recall if the sensor assy uses voltage or a transistor bias to activate the relay on the main board (Item 21) Pull out the tech sheet and see what you can find out. Then test the sensor assy.
    Kelly
    Thanks again Kelly. I will look into the testing of the power and get back to you soon.
    Pete
  • Kelly
    Kelly Aug 24, 2010
    Pete when you check for power make sure you are testing before and after the thermal overload (2 checks) Check after the thermal overload FIRST and if the unit shuts off check power on the input side of the thermal overload. If you have power before but not after the thermal overload you know it tripped. The next question would be why....?
    This can be caused by:
    1. Loose contacts on the compressor terminals
    2. A dragging rotor / armature in the compressor
    3. Bad compressor winding
    4. A bad run capacitor (Check by removing one set of terminals and read continuity several times on R x 1000 each time you probe reverse the leads. If you see a jump on the meter capacitor is good. No jump when leads reversed = bad run capacitor. (Analog mete ris best for this check)
    Read continuity of the compressor terminals to a ground on the compressor. (All terminals disconnected) Usually NONE of them will read to ground and if there is a problem 2 of them will read to ground. If that is what you discover that 2 terminals read to ground your looking at a bad compressor. Hopefully we are not at that point (compressor change) in trouble shooting. My thoughts are if the compressor is bad... the cost of repair will be equal to if not greater than the cost of the whole unit.
    Kelly
  • 6,993 Answers
Usually, dehumidifier stops running when the water tank is full.
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted.
Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them.
If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck;
Posted on Aug 19, 2010
I HAVE A ge 40 pint dehumidifier it wont run because it says the container is full and there is nothing in it
i did have one of a simmiliar model do just this same thing it turns out i hit the sensor float inside removable bucket part and knocked it out of its little hole it fits in , hence the it no longer connects with other part of overfill sensor thats buryed inside machine, so it allways says its full , i put the little float back in it's hole and now it works ok
Oct 20, 2014 | GE Dehumidifier With 40 Pint Capacity
It wont turn on at all? is there a fuse in it that can be replaced?
If there is a fuse then it's blown for a reason.
You do know there has been a recall on some 30 pint dehumidifiers? How old is yours?
Jun 24, 2014 | GE 30 Pint Portable Dehumidifier
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
I HAVE A WHIRLPOOL 25 Pint Dehumidifier model AD25BBL2 serial starts with QM. Anyway it Seems to work ok as water does collect in water tray. About every 30 minutes it makes a single KNOCK NOISE. Unsu
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
May 21, 2014 | Whirlpool 25-Pint Dehumidifier
How do you turn on the 30 pint KU34313 dehumidifier
I think you have to put water in it then push the start switch. The manual has a complete set of instructions.
Feb 21, 2014 | KUL 30 Pint Dehumidifier
Never no water in dehumdidifer to empty
I'd suggest you (1) make sure dehumifier is plugged in, (2) the circuit it's connected to is live (breaker not tripped and fuse not blown - this is easily tested by plugging in an appliance (e.g., hair dryer) you know works). If the unit turns on, it is likely defective - unless there is a hose connected to the dehumidifier that reroutes the water removed from the air to a drain (is there moisture collecting somewhere within 6-10' of the unit?). If it doesn't turn on, and you've troubleshooted the above to ensure there is electricity to the receptacle, then it's either defective or the moisture setting for removal needs to be adjusted for the humidity in your basement. Perhaps it's dryer down there than you thought, or your hygrostat (? - whatever the doohickey is called that senses humidity level) is set at too high a level that it never turns on/trips in your area. Hope it helps.
Jul 31, 2012 | Haier 30 Pint Dehumidifier
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
Sep 01, 2008 | Dehumidifiers
DEHUMIDIFIER | ADR556RH
The Efficiency Factor (EF) is a guide to a dehumidifier's operating cost. The EF is the amount of water, in litres, a dehumidifier removes at 27°C (80.6°F) and 60 per cent relative humidity for each kilowatt hour (kWh) of electricity. If electricity costs 8 cents a kilowatt hour, which it does in many parts of Canada, a unit with an EF of 1.2 will remove 15 L (32 U.S. pints or 3.3 imperial gal.) foreach dollar in electricity costs. An advanced unit with an EF of 2.4 will remove 30 L (63 U.S. pints, 6 1/2 imperial gal.) of water for each electrical dollar spent. Because condensation gives off heat a dehumidifier acts as a heat source. This can be useful in spring or fall, when basements tend to be cool. In mid-summer, the heat added by a dehumidifier is counterproductive.
Sep 07, 2007 | Danby DDR583R Dehumidifier
Kitchen Ranges Logo
177 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
