Question about Cameras
When I look at the images on the 3" screen sometimes I get flashing black areas or certain parts of the photo flash.
  • kakima Aug 20, 2010
    It sounds like you're seeing blown-out highlights. These are the portions of your photos that have lost all detail and gone pure white. The best fix is to reduce the exposure and shoot again.
    Depending on the camera, there may be a way to change the view so you don't see the blinking. What make and model camera are you using?
  • kdocding56 Sep 28, 2010
    I am have a nikon D3000. Love the camera!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Receiving no response to my query in over a month, I assume it was blinking highlights as I mentioned, and my suggested fix solved the problem.
Posted on Sep 23, 2010
  • kakima Sep 28, 2010
    On the D3000, you're definitely seeing blown-out highlights. You can correct them as described earlier. If you simply don't want to see them, press up/down on the multiselector to cycle through the different views of your photo.
    Thanks k_akima for your input and sorry it took so long to respond we took a long vacation. Problem solved!!! Thanks!
Top edge of my photo is a black diagonal shadow
Sounds like it could be vignetting from either a lens hood or an accessory. Are you seeing this in all photos or flash only? If flash, sometimes a wide shot with a lens hood on will block the flash output and cause the described shadow line.
Feb 08, 2014 | Canon Eos Cameras
When i view my pictures certain white images have black color flashing in them
That flashing is the part of the image that is overexposed. See camera manual. Meter off a neutral part of the image.
Apr 19, 2011 | Nikon D40x Digital Camera
When playing Xbox 360 Games i get Flashing lights/Lines
sounds like the graphics chip is on its way out might just be a cold solder joint normaly turns to 3 red lights when ppl mention this to me
Jun 08, 2009 | Sony Playstation 3 (PS3) Console
Video "flashes" white areas when playing certain games.
this was happening due to u r virtual memory, increase the same and try
May 25, 2009 | Dell Studio 17 Laptop
Image playback
Are you saying that part of the picture displayed on the camera screen flashes black? If so this is normal as far as I have read. It shows there is too much light on that part of that image. You can alter it not to show it flashing.
Jan 06, 2009 | Canon EOS 40D Digital Camera
LCD screen flashing
Hi!
This is a feature and not a defect of the K100D. You can turn this off by going to the menu and going into the second tab (playback menu). Once there, go to preview display, where you will have 3 options - off, histogram and brighten areas. Set this to off (your camera is set to brighten areas, that is why the white parts of your photos appear to be blinking).
Hope this helps!
Oct 27, 2008 | Pentax K100D Digital Camera
LCD screen flashes
There is nothing wrong with your camera - It is doing what it is meant to do!
The purpose of the flashing areas is to drawn your attention to parts of the image that are over-exposed. In an ideal world nothing would ever be overexposed, but if the image has both very dark and very bright areas, the camera cannot capture both - something has to give! The flashing areas are just to let you know.
It's covered on page 52 of the manual.
Matt
Apr 09, 2008 | Nikon D40x Digital Camera
Lec screen flashing black areas when pictures are played back
Flashig areas show HIGH KEY or HIGHLIGHTS in image, these areas indicate where exposure compensation can be made. They also change to normal function on first magnification point.
Check the manual on highlights also good reading in the histogram section and you will start to understand about contrast and exposure.
Have FUN.
GORDO
Sep 07, 2007 | Nikon D40x Digital Camera
Spots on image when using built-in Speedlight flash
As is common in many compact digital cameras where the built-in flash is very close to the lens strange reflections can appear in images under certain conditions. Particulate matter in the air in front of the lens (between the camera and subject) such as water vapor (as in a cloudy day), smoke, dust or other items can reflect light directly into the lens causing neutral colored white/grey semi-transparent spots to appear in the image. In extreme examples there may be many of these spots in an image or there may be only one per image. Also, since these spots are completely random they will move or disappear from image to image. For example, if two images are shot consecutively with the same camera settings one image may have spots while the other is clean. To avoid these spots: When possible, avoid photographing in smoky, dust, or cloudy areas Do not use the camera's flash in locations such as above Use an external Speedlight flash if a flash is needed Review images on the camera and re-shoot if spots are visible Cleaning the lens will not have an effect on these spots, as the particles that cause this are not on the lens itself.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
