Question about Kenmore Elite 900 sq. in. Cooking Area Gas Grill 16690\17690
Kenmore elite16690 gas grill - main burner replacement
Have had our Kenmore Elite gas grill, model 16690, for 5 plus years now and some of the parts are starting to show their age. I do not have the assembly instructions for the grill, and I need to replace the main burners and air shutters, the main burner bracket as well as the gas collector boxes. How do I do all of this? Or any idea where I can get a set of assembly instructions to help with the repairs?
  • 2 more comments
  • antman65 May 07, 2008
    thanks for getting back I did not see a sticker on the grill, or are you referring to the item numbers for the replacement parts?
    thanks
  • antman65 May 15, 2008
    thanks, I was able to complete the repairs - took some time with no manuals, but all is working like brand new again - again thanks
  • eric bosman
    eric bosman May 11, 2010
    i will try to get any info for you
  • eric bosman
    please give me the item number which should be on the sticker too
  • 3 Answers
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
I have a Kenmore Elite Model 16690. What is the best website for replacement parts for this grill?
First, since it's a Sears house brand, I'd start online with Sears Parts Central. Depending on which parts you're looking for, you can also try Appliance Factory Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/kenmore/
Keep in mind, Kenmore doesn't manufacture anything. It's just a house brand name for Sears appliances. Actually NexGrill manufactures the Kenmore Grill line. So contacting them 800.913.8999 is also a possible source for parts.
Hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Sep 20, 2011 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore LPG Grill Model 141.16313800 I last used this grill 2 weeks ago and there are no problems. Yesterday I tried to use it but I can't light the grill. So I replaced the propane tank (the old one...
Relace your propane regulator, they do go bad form sitting around, had the same problem you have. you should be able to disconnect from the grill, turn on the regulator and smell the propane, if not it's bad.
Oct 19, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
The first two burners on the left light and have good gas flow. When I light the middle and the left two burners the flames flicker and go out, like there is not enough gas. I cleaned the burners, tried...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 22, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore elite lpg grill #16690 ignition starter doesn't work what to do?
The ignition module must be replaced.
Check the battery first and make sure it is fresh.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 21, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Middle burner of 3 is just a large flame.
Either the burner or the line to burner could be sooted or dirty
Apr 19, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
My kenmore elite grill has a ceramic cooking grid. it is 1 yr old.recently a problem developed. the ceramic grid lights as usual, but does not stay lit.once i let go of the knob the burner goes out. thanks...
check thermo coupling., its purpose is to keep heat at flame area-helps keep flame lit,like a pilot light... clean it with a finger nail file LIGHTLY- or use sand paper LIGHTLY, just to clean surface..
Nov 27, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Grill does noty get hot
try opening the tank very slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 10, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
One side of the grill cooks on lower temp then the other side.. tried new burners but that did not help, what can i do
close your burners up sounds like they are open to much also you make not have enough gas going to the grill, if this is your grill in the picture then you need a half inch line for it
Aug 13, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Cover needed for Elite Grill 17690 w/islands
I just got off the phone with Grand Hall USA and spoke with Tameka. When Sears asks them to make things like this, they send them a couple samples. At the time of this email, Grand Hall has 6 of these left in stock with (I would assume) no replacements on the horizon.
The number is 214-550-8031 and they run $74 plus shipping. I hope this helps you all out. It took me a week of searching, but we got it done........thanks.
Rollo T.
Jan 26, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore Elite 900 sq. in. Cooking Area Gas Grill 16690\17690 Logo
798 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
