Question about Canon Office Equipment & Supplies
E069 problem with my ir 105 tell me what to do?
  • 1,219 Answers
these means that you have high voltage error, probably in high voltage pcb or somewheare in transfer assy.
These can occure if you mess around with bias settings or if you have fluctuation in your power supply network. The network should be checked first.
Here you go the things that can be faulty also:
- Check if the transfer charging assembly and separation
charging assembly are mounted properly.
- Check if the connector (T701, J723, J730) of the HVDC
PCB is mounted properly and also check the wiring.
- Replace the HV-DC PCB.
- Replace the pre-transfer charging assembly
Hope that helps!
Posted on Aug 20, 2010
What is solution for E240 in canon ir 105??
E240 is a communication fault between the DCC and main controller.
Several cases were reported where the HDD was causing this. Symptoms included: Control panel locking up, machine suddenly powering off, and E240.
One case reported was resolved by replacing the main controller.
Perform HD-CHECK in service mode. If this doesn't resolve the problem replace the HDD.
Oct 30, 2015 | Canon imageRUNNER 105 Printer
In ir 105 some words print very light and some times invisible
Use Menu to clean Printer Heads Also ink might have run out !
Mar 17, 2015 | Office Equipment & Supplies
Erro code e000086-0000
CANON IR 105 ERROR CODE E000086-0000
May 26, 2014 | Canon Imagerunner Ir 105 Copier Printer...
Canon ir 105
sir what solution error 69
Jan 29, 2014 | Canon imageRUNNER 105 Copier
E000069-000 Imagerunner 8500
An E069 code indicates a fault with the transfer charging assembly. TP02-015 lists certain areas that should be checked to prevent this code. Additionally, a bias voltage is applied to the fuser assembly and the paper feeder guide and if this bias voltage shorts to the frame it will cause E069 codes.
Mar 14, 2010 | Canon imageRUNNER C3220 Color Copier
Canon ir 7200 error code e069. Replaced the chargers but the same thing persist.
The large tr/sep charger on the bed has three pin style contacts at its rear. When you raise the bed the three contacts lift and make contact with leaf springs that press against the charger pins delivery charge to the coronas. These leaf springs become bent back and need to be bent to original position in a triangular configuration.
Aug 09, 2009 | Canon imageRUNNER 7200 Copier
Where can i find pc drivers for canon ir 105
Go to www.canonusa.com and navigate to support and drivers. Then select your product and download what you need.
Apr 20, 2009 | Canon imageRUNNER 105 Copier
I recieved Code E069 in my machine
hi
error E069 is high voltage leakage?clean transfer unit and separation corona,
Jan 15, 2009 | Canon imageRUNNER 8500 Copier
253 people viewed this question
old marine
old marine
