Will not get cold stays warm. filter is clean. only 2 years old.
  • 139 Answers
Is the compressor running ? may need a new start capacitor for compressor or a hard start one
Posted on Aug 21, 2010
It is three and a half years old and ices up even at warm temps.
The problem you're having is generally caused by the air intake filter needing to be removed and cleaned and/or the cooling coils need to be cleaned.
I assume you already know how to remove and clean the filter, since you've had the unit for 3 1/2 years, so I won't bore you by addressing that.
The coils can be cleaned with warm water and a mild dish washing detergent using a sponge or rag. Once they have been wiped down, rinsed and dried, apply a light coating of WD40 to the coils.
Hope this helped you & thanks for choosing FixYa.
Sep 19, 2011 | Kenmore 54701 Dehumidifier
Hi. My 2 year old Friedrich CP10E10 window unit is not cooling the room like it should/like it has. I followed obvious troubleshooting steps per the operation guide, including thoroughly cleaning filter....
Check the OUTDOOR coil... it sounds like it is clogged up and the system is cutting out on high pressure...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Friedrich CP10E10 Thru-Wall/Window Air...
I have a 2006 Freestar with a 3.9 Engine . When it is cold it has a miss when i step on it. But it gets better when it starts to warm up. Almost seems like a spark plug miss
Spark Plugs ---change at 70,000 miles
O2 Sensors--change at 100,000 miles (front 2 only)
Gas Filter--every 3 years/30,000 miles
Air Filter ---every 3 years/blow off once every year
MAF Sensor---Clean once a year or more often
Ignition Coils--- most definitely will go bad,at
least 1 a year. (Any Check Lights or Codes ? )
When cold, it isn't in closed-loop, and runs on
Long Term Fuel Trim--not on O2 Sensors ,until
warm
Let it warm up at least 4 minutes in cold weather,
go light on the gas for first 2 miles
Feb 22, 2011 | 2006 Ford Freestar
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
HAIER 1 YR. OLD A/C UNIT BLOWS ONLY WARM AIR
well it sounds like the compressor is not turning on. does it have thermostat? if so turn it way down. clean any filters. is it a window unite or portable most of them are too costly to repair unless you do it your self.
Jul 06, 2009 | Heating & Cooling
2 cycle barely runs on half choke
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 23, 2009 | Homelite Garden
Freezer has been warmer than normal lately
check the door beeding which make seal between the body and door.Clean with mild cold water and check it is sealing properly while it is closed.check the compresor ,it should be light warm not hot.
Jun 03, 2009 | Refrigerators
AIR NOT COLD ENOUGH
sounds like it loss some freon
May 02, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
