Question about Whirlpool Dryers
My dryer wont heat up. The ignitor coil glows but it only heats up on occasion.
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 20, 2010
2 Suggested Answers
  • 77 Answers
SOURCE: maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Posted on Apr 18, 2009
I have a gas dryer. the glow plug works but wont stay on
You are likely in need of new coils to make your dryer heat again. If the ignitor glows, the thermal fuses and thermostats are good. The coils sit directly on top of the gas valve, are easily replaced and inexpensive. CLICK HERE for the coil kit to get your dryer heating again. Using coupon code 1050 will save you some money!
Jan 12, 2011 | Whirlpool LGB6300 Gas Dryer
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
Dryer wont turn off. also no heat
it won't turn off because there is no heat. check your ignitor. if ok check thermal fuse. if all ok and ignitor glows change valve coils.
Jun 14, 2010 | Whirlpool LGR3624JQ Gas Dryer
My LG Dryer DLG5988W wont always heat up. The
Dryer ignitors are not as tempermental as oven ignitors. If it glows, the problem is most likely is not the ignitor. One of the coils on the gas valve is the problem, but with LG, you have to get the entire gas valve, as the coils are not available as seperate parts. By the way, if you are testing the dryer with the front off, you have to make sure to cover the drum opening with something (like a piece of cardboard) so that you will maintain proper air flow for the burner.
Jan 25, 2010 | Dryers
My whirlpool dryer wont heat up
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Oct 27, 2009 | Dryers
Dryer does not heat up
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
GE gas dryer, no heat, new ignitor
Hi!! make sure that you have 120 volts going to the glow ignitor.the gas valve will not turn on the gas if the ignitoe wont glow..if it glows the check yout coil boosters they are round and are located by the gas valve.then if not you have a bad timer.they are usually round and are black..good luck..
Jan 03, 2009 | Dryers
NO HEAT
if ignitor glows probably coils if no glow possible thermal fuse usually located on blower housing ..short white object
Aug 04, 2008 | Whirlpool LGR5634L Gas Dryer
Dryer turns but no heat
In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. If 3-5 yrs old, the igniter has probably gone bad. ($50.00 to $90.00 for igniter). The coils also have an occasion to go bad, albeit rarely.
May 11, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out first...Catriver..post back.
Mar 15, 2007 | Roper RGS7745PQ Dryer
Dryers Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
