Question about Sharp R-1610 Microwave Oven
I am trying to remove my R1610 Sharp microwave . . . I have remove the screws from the top and front top what else is there?
  • Sharp Master
  • 9,047 Answers
We have the service manuals for these models and have uploaded them to our site here and here to help you.
Or our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you're having trouble with the display or cooktop lights, we solve these problems for the $39.95 with a one-year guarantee.
Posted on Aug 21, 2010
How to remove sharp r-1440 microwave oven from wall.
I am not positive about this specific model but on a good amount of the Sharps I have worked on in the past they typicall have long screws that go from the top front of the units to the back of the unit where they screw into the plate mounted to the wall. If you remove the plastic vent along the top front of the unit above the door a lot of the time you will find screws there that you loosen to lay the machine toward you and then you have to lift it off of the bracket and take it out. Good Luck
Aug 13, 2017 | Sharp Microwave Ovens
How do I check or replace a fuse in my Sharp R 1850A convection/microwave?
Unplug the microwave first.
Then carefully remove the exterior panel on the right of the unit.
The screw is at the top under the front grille/vent..
Behind this cover near the bottom there should be a ceramic fuse.
Carefully remove it and test it with an ohm meter for continuity.
If there is no continuity replace the fuse.
Jan 03, 2016 | Sharp Microwave Ovens
Trying to remove 1874 Microwave from 05 Dynasty. Mounted in slideout
Dynasty, There 2 long bolts toward the front floor of your overhead cupboard, could be under false floor of same. The lower underside will possibly be secured to mounting plate at back. Be sure to remove these screws otherwise you may bend your mounting plate.
Feb 15, 2012 | Sharp R-1874 Convection/Microwave Oven
How can I remove the face to get to the led numbers on sharp model R-510ak The screen has tilted and cannot be read.
take the top cover off when all screws are out pull the cover off towards you to release front clamps then unscrew the silver hinges at top and bottom of microwave then replace in reverse order
happy fixing
merry christmas
Dec 07, 2010 | Sharp Microwave Ovens
How do I uninstall an old Sharp R-1450 Carousel over the stove microvave oven? I removed the screws from the top that it hangs on and it still won't move. Help and Thanks.
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. That is the only other way that they mount to the wall.
Good Luck
Dec 18, 2008 | Sharp R-1480 Microwave Oven
How to remove a sharp r 1481 over the counter microwave
If you are referring to an over your stove combination microwave/ vent system then they are typically secured thru the cabinet above them. Try opening the cabinet directly over the oven ( you may need a step ladder to see the mounting hardware) and look near the front of that cabinet for two screws on the bottom of that cabinet. These two screws go thru the cabinet and support the front of the microwave oven. You may also see the power cord for that mircrowave oven plugged into a receptacle inside that cabinet. Unplug that cord and then begin unscrewing the two screws. ( it's best if you have a helper work with you).. as you unscrew them, the front of the microwave should begin to drop down a bit. Once the screws are removed, you should be able to lift the back panel up a little bit to free the microwave of the wall mounting bracket. Once that is doen, you will be able to remove the microwave. I am assuming that your microwave does not have any vent pipe secured to it. If it does, then you will need to seperate that from the microwave vent on top ( assuming it is venting thru the top) .. These microwaves can be vented in any of 3 ways, thru the top, outthe back or configured to vent back into the room. In any case, you should see ductwork while removing this from the cabinet. Hope this helps you get the job done...
Sep 13, 2008 | Sharp Microwave Ovens
R1610 microwave
It's called a vent louver. You'll need the exact model # from inside the microwave when inquiring to get the correct color.
Check with www.microwaveglasstrays.com or call them toll free @ 1-877-894-0035 to order. (I think they're somewhere in the $35 range.
Aug 28, 2008 | Sharp R-1610 Microwave Oven
R-1460
Check fuse. Remove 3 screws from the plastic grill located at along the top front of the unit. Remove the phillips head screw above the control panel. Slide up and pull out to partially remove control panel. You will see a white fuse. Replacement is CD3G 125v 20amp or BUSS ABC 20 or Little Fuse 314020 at 250v 20a. Radio shack caries the ABC.
May 12, 2008 | Sharp R-1460 Microwave Oven
1990 Sharp Carousel II over microwave / vent hood
Sharp calls that the turntable coupler when it's a separate part.
If it's part of the the part with three legs, that is called the turntable support.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
If yours is model R1610, we actually have that full service manual on our site at http://www.microwavedisplay.com/r1610_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 02, 2008 | Sharp R-1610 Microwave Oven
Sharp r-1610 microwave
It could be the turntable motor, the turntable support (with built-in coupler) or a problem on the control board. I would first look at the 3-legged turntable support with built-in coupler to see if it got hot and warped. It should be flat across the top from the center to the end of the legs. If the support's legs are pointing a bit downward, it will prevent the coupler from making contact with the motor shaft. I've held bent ones a few inches over a gas burner to heat them up where the legs meet the center hub, then set something a bit heavy on it to hold it in place while it cools. If it needs a new one, it is part # FROLPB025MRK0 and it runs $19.50 retail at Tritronics. A quick (but not necessarily definitive) test of the motor is to grab the shaft gently with pliers and gently try to turn it. If it moves slowly and makes a high-pitched whining noise, it's likely okay. If it won't turn or grinds, it is bad. The number for the new turntable motor is RMOTDA264WRZZ and it retails for $8.87. Please note that you may need to look under model R1600, R1600, R1601, R1601, R1610, or R1612. They are all mostly the same. Tritronics is at http://www.wehaveparts.com The service manual for the R1610, R1611, R1612 can be downloaded at: http://www.microwavedisplay.com/R1610.pdf There may be a grommet bewteen the mtoro and turntable support. Don't lose that! Be safe!
Dec 03, 2006 | Sharp R-1610 Microwave Oven
Sharp R-1610 Microwave Oven Logo
90 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
